Devo 8s Deviation with phoenix sim v4.0
- EVERNIN
08 Mar 2013 02:08 #7505
by EVERNIN
Devo 8s Deviation with phoenix sim v4.0 was created by EVERNIN
Hi, just upgrade my devo 8s to Deviation and just installed phoenix sim v4.0 to my pc, have been trying to use my devo tx with sim but it does not recognize it, using windows 7 64bit, have tried directly with phoenix interface(dongle) to my Devo and also using a stereo to mono adapter with no success,any help will be grateful.
one more question, how do I know if my Devo 8s is either 100mw or 10mw???
sorry I am a beginner.
Thank you.
Ever
Thank you.
Ever
- shadow
08 Mar 2013 02:43 #7509
by shadow
Replied by shadow on topic Devo 8s Deviation with phoenix sim v4.0
You need to select ppm as the protocol
I attached the ini file I use for the sim.
08 Mar 2013 05:29 #7516
Replied by FDR on topic Devo 8s Deviation with phoenix sim v4.0
With deviation it will be definitely a 100mW one, because that limitation was in the fw...
08 Mar 2013 07:10 #7518
Replied by rbe2012 on topic Devo 8s Deviation with phoenix sim v4.0
Ever,
if you use a nightly build the PPM output may be used for debiggung informations so it will not be available for a sim.
Use the last official version (2.1.1) instead.
- Joshua
08 Mar 2013 08:10 #7519
by Joshua
Replied by Joshua on topic Devo 8s Deviation with phoenix sim v4.0
nightly build's works fine for me with phoenix sim v4.0.
ciao, Bernd
ciao, Bernd
- Hexperience
08 Mar 2013 12:00 #7522
by Hexperience
Replied by Hexperience on topic Devo 8s Deviation with phoenix sim v4.0
- EVERNIN
10 Mar 2013 02:04 #7574
by EVERNIN
Replied by EVERNIN on topic Devo 8s Deviation with phoenix sim v4.0
Thank you all of you, Now I am using my Devo 8s/Deviation with Phoenix v4.0n,
Shadow,using your model8.ini file, thaknks, will be asking for mor support since I am a beginner.
- shadow
10 Mar 2013 05:51 #7585
by shadow
No Problem Enjoy.
- pypass
27 May 2014 03:50 #23652
by pypass
Replied by pypass on topic Devo 8s Deviation with phoenix sim v4.0
Easy to set...just go to protocol choice and check ppm
Time to create page: 0.208 seconds
- Devo 8s Deviation with phoenix sim v4.0
