Devo 12s Touchscreen
- Wene001
13 May 2013 17:42 #9932
by Wene001
Devo 12s Touchscreen was created by Wene001
hello to all deviation users out there
my devo12s touchscreen does not work perfekt since the first days i own this tx.
sometimes it has a little offset.
i click next page in menue and got the previous and so on.
pressing hard - and its accurate
pressing soft - sometimes it recognices the "click" 5mm left
a devo8 i gave to a friend and my devo6 are working perfekt.
is this a known issue?
GHEERS Werner
GHEERS Werner
13 May 2013 18:24 - 13 May 2013 18:25 #9933
Replied by rbe2012 on topic Devo 12s Touchscreen
Hello Werner,
I am quite sure you've done, but: did you calibrate your screen? You have to do this every time you copied a new filesystem / tx.ini on your tx because the values PB has evaluated with his tx might differ from those you need.
Last edit: 13 May 2013 18:25 by rbe2012.
- Wene001
13 May 2013 18:35 #9935
by Wene001
Replied by Wene001 on topic Devo 12s Touchscreen
yes, calibrated
yesterday i progged some of my models in deviation
and sometimes it clicked other boxes as it should.
i think i can ignore tis little issue
- richardclli
14 May 2013 01:20 #9965
by richardclli
Replied by richardclli on topic Devo 12s Touchscreen
I found this issue in my Devo 8S screen, seems there maybe a problem of resistive screen when clicking too light. Not sure if it is the problem of the screen, or can be improved with software filtering out click gliches.
- Raimili
- DEVO 12S "Slope-Gliders" wellcome
17 May 2013 01:20 #10062
by Raimili
...(hoping that anyone creates a simple Mixer GUI (Sailplane) for noopes like me)
Replied by Raimili on topic Devo 12s Touchscreen
Hi Wene,
i have this problem also.
Sometimes (i think it´s in the mixers section)
I´ve choosen a box and it opend another.
It´s not a hardware problem, i think.
Momentaly i work with the org. Firmware and frd´s library - all the touchcreeen works fine.
Greetings from Germany
Raimi ....
(hoping that anyone creates a Mixer GUI for noopes like me)
Raimi ....
- Wene001
17 May 2013 17:21 #10087
by Wene001
anyone seeing a chance to get this resolved by tuning the software?
- tazdevil
17 May 2013 18:42 #10088
by tazdevil
Replied by tazdevil on topic Devo 12s Touchscreen
hi,
got the same problem with my devo 6s on v3 firmware
sometime it,s work sometime no, pb occure when creat model
supress the model and the problem disapear, very strange
- richardclli
20 May 2013 00:37 #10118
by richardclli
i think the touch screen driver need to rime the reading of values and reject some short readings. Whicg piece of code is the touch screen driver? I have some old code for keyboard control which can help to enhance this problem.
Time to create page: 0.116 seconds
- Devo 12s Touchscreen
