deviation and expo
- Dakota
22 Sep 2013 14:34 #13986
by Dakota
deviation and expo was created by Dakota
I would like to put expo on the aileron channel.
Not for Helis !
I can`t find the way how it works ??
Not for Helis !
- RoGuE_StreaK
22 Sep 2013 23:02 - 22 Sep 2013 23:04 #13997
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic deviation and expo
Which transmitter; 7E/10, or 6S/8S/12S?
Change the curve type to "Expo" (might currently be "1-to-1"?), then click on this "Expo" box to enter the settings area. For a 7E/10 this involves highlighting the box (can't remember if you use R+/L- or Up+/Down-) then pressing ENT, on a 6S/8S/12S simply press the Expo box.
The thing to remember is that on some spin boxes (boxes with arrows to change contents), some of the contents themselves are buttons; you spin to choose, then press to change.
Doesn't matter whether it's for a heli, plane, car, tank, or killer-robot-monkey, it all works the same.
Last edit: 22 Sep 2013 23:04 by RoGuE_StreaK.
- Dakota
24 Sep 2013 12:42 #14039
by Dakota
Replied by Dakota on topic deviation and expo
Thank you,
i found my mistake. AnytimeI had edit an inut an he screen, I ave to press "ok" and go back. Then the input is saved.No "ok" - no save. !!
24 Sep 2013 17:33 #14041
Replied by rbe2012 on topic deviation and expo
Yes, it's for safety. You have the chance to redo changes before applying them to a running machine...
Time to create page: 0.082 seconds
- deviation and expo
