Devo 7e help
- Tomcor
17 Dec 2013 00:00 #16726
by Tomcor
Devo 7e help was created by Tomcor
When in the mixer menu. Why does it show exclamation marks in front of the src?
Such as !AIL. !ELE
Any help would be great
Such as !AIL. !ELE
- WheresWaldo
17 Dec 2013 00:17 #16727
by WheresWaldo
All channels with an exclamation point are inversed.
Replied by WheresWaldo on topic Devo 7e help
Tomcor wrote: When in the mixer menu. Why does it show exclamation marks in front of the src?
Such as !AIL. !ELE
- RoGuE_StreaK
18 Dec 2013 20:48 #16781
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo 7e help
Also in programming it can be "not", so as WheresWaldo said it can be seen as inversed, or for the likes of buttons it's handy to think of it as NOT for simplicity;
eg
Switch = FMOD1 means when FMOD1 is on
Switch = !FMOD1 means when FMOD1 is not on, so for example both FMOD0 and FMOD2 will work in this case; otherwise you'd have to specify the same process for both Switch = FMOD0 and Switch = FMOD2
eg
Time to create page: 0.607 seconds
- Devo 7e help
