Devo 7e v4.0.1 and Hobsan X4 H107L Binding issue
19 Jan 2014 07:09 #18665 by droople
Hello
I got my Devo 7e today, and installed Deviation 4.0.1 and added the V911 TX radio module.
I am trying to bind my Devo 7e and Hobsan X4 107L, but it shows binging and never get banded.
I'm a noob on the transmitter, I'm not sure are there any model/protocol file for H107L I could download.
Thank you in advance :)
19 Jan 2014 07:21 - 19 Jan 2014 07:25 #18666 by John-Boy
Don't forget to edit the tx.ini file and enable the a7105 module. Then look here for more ideas:
www.deviationtx.com/forum/6-general-disc...-bind-problems#18402
Here's a Hubsan config:
www.deviationtx.com/forum/model-configs/1227-hubsan-x4-config
Good Luck... ;)
Last edit: 19 Jan 2014 07:25 by John-Boy.
19 Jan 2014 09:47 #18669 by droople
John-Boy wrote: Don't forget to edit the tx.ini file and enable the a7105 module. Then look here for more ideas:
Good Luck... ;)
thank you John, I checked the both threads and loaded the config,but still no luck :(
here is my tx
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A13
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A14
has_pa-nrf24l01=1
19 Jan 2014 10:19 - 19 Jan 2014 11:55 #18672 by John-Boy
Are you sure of which data line you used?
Try this:
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A14
has_pa-a7105=1
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A13
has_pa-nrf24l01=1
Later....
Last edit: 19 Jan 2014 11:55 by John-Boy.
20 Jan 2014 05:37 - 20 Jan 2014 05:39 #18756 by Daryoon
Yes, it's important to know which location you soldered the NRF24L01 module to.
The TMS or the TCK point.
TMS = A13
TCK = A14
Read my post here and pay attention towards the end where I talk about that.
www.hacksmods.com/2013/05/nrf24l01-devo7e-pinout/
Last edit: 20 Jan 2014 05:39 by Daryoon.
14 Mar 2014 07:20 #21535 by droople
Thank you John
I found the reason is that I did put a7105 chip on the board :oops:
Now it was fixed.
But the Aile controls the rolling leftward and rightward, and Elev controls the forward and backward. It's the opposite way I want.
Could you tell me how to swap the control between Aile and Elev?
14 Mar 2014 12:46 #21539 by John-Boy
I don't know what to say.... If you switch the functions of the Ailerons and Elevator you won't be following any control scheme I have heard of.
Maybe you want to try it as is so you will be ready for other aircraft that follow standard control layouts?
If not, follow the directions of the Advanced GUI. Select Channel #1 and change its source from Aileron to Elevator. Then change Channel #2 source to Aileron.
Good luck?
14 Mar 2014 13:00 #21540 by droople
sorry, I'm confused with Aile and Elev as English is not my first language.
What happened is the Elev controls the rolling leftward and rightward, and Aile controls the forward and backward. And I want to correct it.
14 Mar 2014 14:12 - 14 Mar 2014 14:12 #21546 by John-Boy
I don't think I can help more.... Use the translator here:
Google Translation of Documents
To download the manual in the language you need.
Last edit: 14 Mar 2014 14:12 by John-Boy.
19 Mar 2014 06:03 #21659 by droople
I swap the channel according the manual, I'm not sure why the default config is wrong.
Time to create page: 0.905 seconds
