NOT BINDING DEVO 8S AND NOT POWER OFF
- rerpoteq
05 Feb 2014 10:32 - 05 Feb 2014 11:26 #19855
by rerpoteq
NOT BINDING DEVO 8S AND NOT POWER OFF was created by rerpoteq
hello.
I have a problem with my devo 8s, after putting deviation fw 4.0.1.
devo can not link to any walkera genius cp or v120d and v450, not binding With Nothing helicopter.
when I put the original firmware of walkera command does not turn off, just removing the battery off.
I have tried all the firmwares and the same happens.
deviation not binding
not original and can only turn off When power off remove battery
my friend have other devo 8s and same problem.
deviation not binding and fw original cant power off, only power off if remove battery.
Last edit: 05 Feb 2014 11:26 by rerpoteq.
05 Feb 2014 12:56 - 05 Feb 2014 12:56 #19858
Replied by rbe2012 on topic probably DFuse "upload", no "upgrade"
Have you read the manual before? Sorry for asking, but there are so much important information inside...
The migration process to deviation is also described there. It looks as if you have "uploaded" the firmware, not "upgraded" (in DFuse software; this leads to corruption of the firmware file so download it again). Try to redo the migration steps with the manual in hand and you will get lucky...
Last edit: 05 Feb 2014 12:56 by rbe2012.
- rerpoteq
05 Feb 2014 13:44 #19860
by rerpoteq
Replied by rerpoteq on topic NOT BINDING DEVO 8S AND NOT POWER OFF
image.helipal.com/helipal-devo8-update-firmware-big-1.jpg
yes i install alls deviation and alls original fw and same.
deviation no binding and orig not can turn off, only off if remove battery.
- HappyHarry
05 Feb 2014 13:49 #19861
by HappyHarry
Replied by HappyHarry on topic NOT BINDING DEVO 8S AND NOT POWER OFF
then you are not following the correct installation process, use the proper deviation manual >>
www.deviationtx.com/repository/Documenta...tion8UserManual.pdf/
and follow it to the letter
- rerpoteq
05 Feb 2014 14:05 #19862
by rerpoteq
yes use this manual for deviation.
- rerpoteq
05 Feb 2014 14:09 - 05 Feb 2014 14:10 #19863
by rerpoteq
i have 4x v120d , 2 genius cp ,1x v450, 1x trex 600 mod flybarles.
not binding with devo8s, devo 10 work fine .
problem only devo 8s original firm not can turn off
problem deviation not binding , alls cfw tested.
Last edit: 05 Feb 2014 14:10 by rerpoteq.
- rerpoteq
05 Feb 2014 14:12 #19865
by rerpoteq
alguien habla español?
a alguien le ha pasado eso?
tras poner deviation 4.0.1 devo8s no binding con ningun walkera
si pongo firm original la radio no se apaga cuando pongo en off y sale alerta que no se puede guardar, solo se apaga quitando bateria
- rerpoteq
05 Feb 2014 14:56 #19872
by rerpoteq
mi devo 8s s/n:8 i buyed pak china 10 day ago.
i read this in forum.
"Warning to Devo8/8s users: If you have a very recent transmitter, only the nightly builds of Deviation will work for you and it will be impossible to go back to the stock firmware until Walkera posts updated firmware on their site. If in doubt, ask on the forums first."
- HappyHarry
05 Feb 2014 15:14 #19873
by HappyHarry
sorry I only speak English and gealic
what to do is begin again, so
1: delete the deviation files you already have on your PC.
2: download the corrext deviation 4.0.1 file here >> deviationtx.com/repository/Deviation-Rel...on-devo8-v4.0.1.zip/ and extract the contents
3: connect your transmitter to the pc and power it up while holding the ext button.
4: start the walkera dfuse software, and on the firmware tab flash the file called > deviation-devo8-v4.0.1.dfu by selecting it in the 'file' box and then pressing the upgrade button
5: turn off your transmitter, then while holding the ent button power on your transmitter.
6: open the drive that is your transmitters USB drive and back up your models. then delete everything on the drive.
7: copy the files and folders from the extracted folder onto your transmitters USB drive, copy all apart from
debug-devo8-v4.0.1.zip
8: reboot your transmitter.
9: copy back your models files, and when trying to bind with your v120d02s make sure you have the protocol set as 'devo' and the fixed I'd deleted. also reset your reciever so it will accept a different fixed I'd.
10: after trying this post back explaining what happens
- rerpoteq
05 Feb 2014 15:29 #19874
by rerpoteq
hello friend I have done exactly that with all cfw deviation and have not achieved anything, the worst thing is that when I put the original fw command does not turn off
05 Feb 2014 15:36 #19875
Replied by vlad_vy on topic NOT BINDING DEVO 8S AND NOT POWER OFF
Can you bind your models with original Walkera firmware?
- rerpoteq
05 Feb 2014 15:47 - 05 Feb 2014 15:48 #19876
by rerpoteq
walkera orig firm problem not can turn off, allways on.
only if remove bat turn off.
but no save configuration.
other users of devo 8s s/n:8 haven same problem?
not binding deviation and not can off if re-install orig firm walkera?
Last edit: 05 Feb 2014 15:48 by rerpoteq.
05 Feb 2014 16:28 #19879
Replied by FDR on topic NOT BINDING DEVO 8S AND NOT POWER OFF
Do you use fixed id on those models when you bind them to the DEVO 10?
Because the with fixed id a model can be bound to only one tx, however the auto binding should work...
- rerpoteq
05 Feb 2014 17:27 #19881
by rerpoteq
no fix
binding allways in devo10
- HappyHarry
05 Feb 2014 19:05 #19886
by HappyHarry
if the receiver has bound with the devo 10 you MUST RESET THE RECEIVER FIXED ID and that doesn't mean just switch it off and on
- RandMental
05 Feb 2014 20:09 #19888
by RandMental
Since the Devo8 cannot turn off even with the original software, assuming it was loaded correctly, I believe we have a hardware problem here.
Replied by RandMental on topic NOT BINDING DEVO 8S AND NOT POWER OFF
rerpoteq wrote: walkera orig firm problem not can turn off, allways on.
05 Feb 2014 20:47 #19892
Replied by rbe2012 on topic NOT BINDING DEVO 8S AND NOT POWER OFF
Doesn't this happen too if the library is not reflashed together with the firmware?
- victzh
05 Feb 2014 21:16 #19895
by victzh
Replied by victzh on topic NOT BINDING DEVO 8S AND NOT POWER OFF
Devo's have crappy power electronics which is known to fail in many ways. I have Devo 7 (not 7E) with exact same defect - turns off only when battery plugged off.
- rerpoteq
05 Feb 2014 22:50 #19901
by rerpoteq
i reset bing with cable in throttle but not binding.
with deviation firm i can turn off with orig fw not.
i think not hardware problem, because only fail with ori fw.
- victzh
06 Feb 2014 00:41 #19903
by victzh
I vaguely recall that to reset the fixed id was non-trivial for some of the receivers, I am not sure that yours is the case.
WRT power-off - if original Devo software tries to debounce power-off button and it is very defective, it can fail to switch off. Deviation in contrast does not debounce this button (probably for this very reason) and turns off reliably.
So you may be have a really bad power switch.
Time to create page: 0.392 seconds
- NOT BINDING DEVO 8S AND NOT POWER OFF
