devo 7e Mixer problem setting up tricopter kk2.1
18 Feb 2014 18:30 - 18 Feb 2014 21:30 #20537 by Littlepip
I am having a problem getting the kk2.1 receiver page to show the correct inputs from my radio. I am using a Devo 6 channel rx, and 7e radio.
I have all channels going the proper way i.e elivator up it shows up on the kk2 board.
The problem I am having is on some channels they move the proper way but instead of the channel showing, say -100 to 100 is is reversed and shows 100 at the bottom of the scale and -100 at the top which is backwards to what I expect.
If I look in the transmitter monitor / channel Monitor / stick input, I get this for all models on the radio and they all work ok.
Ail 100 to -100
Eli -100 to 100
Thr -100 to 100
Rud 100 t0 -100
Is this what it should be, or should all channels read -100 to +100, reading for example, throttle full off, -100 full throttle 100. This is what I would expect but I get rudder and ail reading 100 to -100 and eli and thr reading -100 to +100.
My question is should they all read the same range and if so how do I change them to do so in the radio, or is this what it should be .
I hope you can understand me, I am confused and it is hard to explain.
Any help will be appreciated, it is strange not all channels have this behavior only aileron and rudder.
Gary
Last edit: 18 Feb 2014 21:30 by Littlepip. Reason: Made some changes to make clearer
  • rbe2012
  • rbe2012's Avatar
02 Mar 2014 12:33 #21075 by rbe2012
This is the way deviation interprets the stick input values. If you need it reversed you can invert the input in the mixer (use !RUDD instead of RUDD) or invert the channel. See the pictures:
Time to create page: 0.225 seconds
