Devo 10 Output Power
08 Apr 2014 23:07 #22251 by Jman841
Devo 10 Output Power was created by Jman841
I could not find a definitive answer to this.
In Deviation the software allows for 150mW of output power. Is this actually 150mW's being pushed by the Tx?
I remeber with the Devo 7e and the range mod the amp was only 100mW max. 150mW in Deviation was actually only 100mW of output power (I believe).
Is this the same for the Devo 10 or does the software actually allow the hardware to push 150mW?
Thank you! I could not find an actual answer on this, just alot of speculation.
10 Apr 2014 04:13 #22308 by Jman841
Replied by Jman841 on topic Devo 10 Output Power
no one knows?
21 Apr 2014 07:11 #22622 by Jman841
Bump...
21 Apr 2014 08:54 - 21 Apr 2014 09:03 #22627 by vlad_vy
Replied by vlad_vy on topic Devo 10 Output Power
Original Devo 10 output power test.
Deviation firmware can use RF module up to it limit (150mW).
Last edit: 21 Apr 2014 09:03 by vlad_vy.
21 Apr 2014 11:49 - 21 Apr 2014 11:51 #22628 by IMback!
Replied by IMback! on topic Devo 10 Output Power
Also devo 7e without bridging the diode has afaik about 7mw of output power not 100mw
As far as i know no one has tested deviation at 150mw with an analayser, but there is no reason to disturust the pa datasheet as the range at 150 is higher than at 100
Last edit: 21 Apr 2014 11:51 by IMback!.
27 Apr 2014 07:41 #22745 by Jman841
Just so I understand correctly, that sheet says max measured output power is 85.31 mW's. That is the actual output power with the stock Devo 10 pushing 100mW's?
So with Deviation firmware pushing it up to 150mW's we could expect about 120-130mW's if measured with a spectrum analyzer?
27 Apr 2014 14:33 #22751 by FDR
Replied by FDR on topic Devo 10 Output Power
It is not that simple: the output power of a DSSS system heavily depends on the measured bandwidth...
27 Apr 2014 17:20 #22755 by IMback!
Also Honestly obsessing about output power is missguided. All that really matters is Range and that depends on way more factors than output power.
30 Apr 2014 10:10 #22799 by saidem
Replied by saidem on topic Devo 10 Output Power
Hi
What is deviation from deVention to increase the power output of the TX?
Time to create page: 0.900 seconds
