Sequential output channel signal by a switch?
- dc59
22 Apr 2014 00:47 - 22 Apr 2014 03:45 #22644
by dc59
Sequential output channel signal by a switch? was created by dc59
Last edit: 22 Apr 2014 03:45 by dc59.
23 Apr 2014 20:36 #22673
Replied by FDR on topic Sequential output channel signal by a switch?
I don't really understand what do you mean...
Could you describe it more?
- dc59
24 Apr 2014 02:53 #22679
by dc59
Replied by dc59 on topic Sequential output channel signal by a switch?
Sorry for suck English....
I want to set gear switch at channel 1,When I switch from Gear 0 to Gear 1,
Channel 1 can output point 1/A(0),point 2/B(0),point 3/C (+100),point 4/D (+100),point 5/E(0),point 6/F (0),point 7/G (0) step by step , like a pulse (0 -> 100 -> 0).
but now , I just can set Gear 0 = 0(Point 0/A) , Gear 1 = 100(point 3/C) ...
Thank you veay much.
- Kdean
24 Apr 2014 04:53 #22681
by Kdean
Replied by Kdean on topic Sequential output channel signal by a switch?
Maybe use the channel speed/delay???
- dc59
25 Apr 2014 06:52 #22712
by dc59
Hi Kdean,
Thanks for reply.
I try to change channel speed and can't find any thing different ..
Would you please give me some hint?
Thanks for reply.
- Maco33
17 Oct 2020 06:58 #76893
by Maco33
Replied by Maco33 on topic Sequential output channel signal by a switch?
Hi boys, I need help. For my module (see photo) I have to program the exact pulse function on Devo7e (Deviationtx). I have a three position switch and I start in the neutral position (middle). I need: When I switch to one position, I need to transfer a precisely defined pulse (eg 5 seconds) to relay 1. Then I switch to neutral. When I switch to position two (from neutral), I switch relay 2 to the defined pulse length.
Thank you for any help.
- Gerry
- Bbrad
18 Oct 2020 03:45 #76896
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Sequential output channel signal by a switch?
This topic may have some insight for you.
www.deviationtx.com/forum/7-development/...rs-to-channels#29092
- Maco33
18 Oct 2020 16:43 #76898
by Maco33
Thanks Gerry, it's amazing, but I will need many evenings to understand and apply
The important thing is that I already know that it is possible
Time to create page: 0.903 seconds
- Sequential output channel signal by a switch?
