MCPX V2 binding problems
- jens
30 Oct 2014 06:27 #26214
by jens
MCPX V2 binding problems was created by jens
i have i MCPX V2 but i am not able to bind the hell with deviation...
After press "bind" something happens, and i am able to control the blades pitch/nick/roll but the motors don't start (tail motor and main motor)...
The blue Led in the MCPX is blinking...
i tried both protocols DSM2 and DSMX.
Whats wrong?
Jens
Whats wrong?
Jens
30 Oct 2014 09:08 #26216
Replied by FDR on topic MCPX V2 binding problems
Try to increase the scale values of the throttle channel to say 125%...
- jens
30 Oct 2014 09:47 #26217
by jens
Replied by jens on topic MCPX V2 binding problems
I tried, but it dosnt work.
May be i did something wrong during binding?
Whats the correct way?
Connect the accu to the hell, wait for 5 seconds (blue LED ist flashing),
Press "bind" on the deviation software....
30 Oct 2014 12:42 #26219
Replied by vlad_vy on topic MCPX V2 binding problems
Immediately after pressing 'Bind' buton move the rudder stick to full right. Continue to hold the rudder control stick to full right until the blue LED on the 3-in-1 control unit is solid.
- jens
31 Oct 2014 06:02 - 31 Oct 2014 06:04 #26234
by jens
i tried this several times... with no success.
It seems to me, that the MCPX is in "throttle hold" (in the manual described as "throttle hold/motor off) mode.
For explanation: On my DX4e if i push the trainer/bind button one time, its throttle hold. Then the motor goes "off".
On my DX4e Transmitter then i have to push the trainer/bind button quickly 3 times. After that motor is on.
(See picture of manual)
Another question: I it possible to use one of the button right/left from the screen as an additionally switch for using as a channel?
Thanks for help
Jens
vlad_vy wrote: Immediately after pressing 'Bind' buton move the rudder stick to full right. Continue to hold the rudder control stick to full right until the blue LED on the 3-in-1 control unit is solid.
Thanks for help
Jens
Last edit: 31 Oct 2014 06:04 by jens.
- jens
31 Oct 2014 16:48 #26239
by jens
finally i got it....
Rudder Stick to right does it, after unbinding the mcpx
many thx vlad_vy
many thx vlad_vy
- jens
22 Apr 2019 17:59 #74090
by jens
.... hm how to unbind? I didnt know it anymore...
Today i have the same Problem again i cant bind my mcpx. I cant find the page anymore, where is described to umbind from an dx4e (non Computer Remote)
- Fer
22 Apr 2019 19:33 #74092
by Fer
Its been very long ago since i last flew my mcpx v2, but if i remember correctly, there isn't actually a "unbind" mode. I think it gets in bind mode, everytime you plug in the battery before you have turned on the tx. So plug the battery in the heli, then turn on the tx, go to bind menu, hit bind, and hold the left stick to full right for binding with DEVO (DX4e needs stick to full left) for as long as it binds. It should work.
Replied by Fer on topic MCPX V2 binding problems
jens wrote: .... hm how to unbind? I didnt know it anymore...
- jens
23 Apr 2019 06:58 - 23 Apr 2019 06:58 #74105
by jens
Yeah! Thank you! That's it! LEFT Stick!Not the right one. I idiot always took the wrong stick. The DX4e does not care. It also works with right. I have not used my MCPX for so long, just like you. Just didnt know it anymore.
Thx so much.
BTW, what kind of Hell do you fly?
Thx so much.
Last edit: 23 Apr 2019 06:58 by jens.
- Fer
23 Apr 2019 12:41 - 23 Apr 2019 12:42 #74113
by Fer
I have several small to medium hellis. V911-2, an 130X Redbull, a couple of mcpxs. I used to have a couple of 130X too, but sold them for spare parts. The ones i enjoy flying at the moment are XK K110, XK K120 and Tarot 450 FBL.
Last edit: 23 Apr 2019 12:42 by Fer.
Time to create page: 0.173 seconds
- MCPX V2 binding problems
