Help with configuration files.
- jjw_d7e
04 Jan 2015 14:49 #27469
by jjw_d7e
Help with configuration files. was created by jjw_d7e
I have a new Devo 7e with the following setup.
A7105 Wireless RF 2.4GHz Transceiver Module 3.3V Power Supply Module
2.4G NRF24L01 PA LNA Wireless Module
Connected to
Dual Band 2.4/5.8Ghz 6dBi RP-SMA Directional Wireless Wifi Antenna
Standard switch layout (2)
Deviation software 4.0.1
I downloaded a configuration file and icon from here for my Hubsans X4's (L, C & D) and they work fine, thankyou.
My question is I have the new upgraded Syma X5C-1 and the new JJR/C H8-C quadcopter but I'm unable to find any configuration files for these quads. According to the supported modle list the H8-C is but the X5C-1 isn't but I have seen posts about the Syma but no configuration files.
If anyone could point me in the right direction to getting these two quads off the ground using my 7e it would be much appreciated.
Thanks in advance,
Jerry.
Connected to
Thanks in advance,
Jerry.
- aMax
04 Jan 2015 15:03 #27470
by aMax
Replied by aMax on topic Help with configuration files.
Did you use the search tool?
Try this topic...
www.deviationtx.com/forum/protocol-devel...8-syma-x5c-1-x11-x12
Try this topic...
04 Jan 2015 15:29 - 04 Jan 2015 15:29 #27473
Replied by hexfet on topic Help with configuration files.
Support for the X5C-1 is new and not yet in an official build. There's a build for the 7e in the above-mentioned thread, as well as configuration information.
Last edit: 04 Jan 2015 15:29 by hexfet.
- jjw_d7e
04 Jan 2015 15:31 #27474
by jjw_d7e
Replied by jjw_d7e on topic Help with configuration files.
Yes I've been using the search function and yes i saw that post about the X5C-1 you highlighted but a lot of it went straight over my head as i'm "just a newbe"
Time to create page: 0.306 seconds
- Help with configuration files.
