Some Problems with bind and Configurate
11 Jan 2015 13:33 - 11 Jan 2015 13:35 #27626 by alex367
I have successfully installed the NRF24L01 module.
But I have a few problems.
1. I have the WLtoys V272 and I have to rebind it again and again in the menu.
No matter if I have a fixed ID or not !!
I still have a XINXUN since it binds immediately when I start up, even the RX1002 binds immediately.
2. I can fly well and I have 2 switches placed an expo curve, but how can I turn the light on and off?
3. When the battery is getting empty I have bad reception, but I am only 6 feet away. I use the module without external antenna. THe other module I have ordered.
Can I am V272 install an extra antenna and if so where ??
4. I have a Foxnovo USB dongle for simulator but I can only use it with the original Walkera software.
With the deviation Software of the transmitter is not recognized.
The INI V272:
name=NANO Copter
mixermode=Advanced
type=plane
[radio]
protocol=V202
num_channels=6
tx_power=150mW
[channel1]
reverse=1
max=100
min=-120
template=expo_dr
[mixer]
src=AIL
dest=Ch1
[mixer]
src=AIL
dest=Ch1
switch=RUD DR1
scalar=60
[mixer]
src=AIL
dest=Ch1
switch=ELE DR1
scalar=40
[channel2]
max=100
min=-100
subtrim=130
template=expo_dr
[mixer]
src=ELE
dest=Ch2
[mixer]
src=ELE
dest=Ch2
switch=RUD DR1
scalar=60
[mixer]
src=ELE
dest=Ch2
switch=ELE DR1
scalar=40
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
reverse=1
safetysw=AIL DR1
max=100
min=-100
template=simple
[mixer]
src=RUD
dest=Ch4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=64,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Ch2
Small-box=2,39,Ch1
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
Greetings
Alex
Last edit: 11 Jan 2015 13:35 by alex367.
13 Jan 2015 14:04 #27650 by christx
Replied by christx on topic Some Problems with bind and Configurate
Dear Alex,
This post is unfortunately not an answer to your question.
I just want to add my experience with binding some models:
I posess a devo 7e and a mini cp plus a hubsan X4 and
an align Trex 100.
X4 and align bind without problems but for the mini cp it's not
so simple:
Some .ini files work and some don't bind even if i press the bind
button in the model menu.
i never tried to configurate the fixed id.
13 Jan 2015 17:08 #27657 by hexfet
Replied by hexfet on topic Some Problems with bind and Configurate
1) Don't have a v272 but many of the small quads require binding every power-up. If you're running the nightly version there should be a protocol option to bind when the tx is turned on.
2) Light control should be on channel 5. Flips on channel 6.
4) Is the protocol set to PPM when you try to use the simulator?
13 Jan 2015 19:20 #27660 by Deal57
Replied by Deal57 on topic Some Problems with bind and Configurate
1) My V272 always needs to rebind, as does my JXD392.
2) There are several version of the Model.ini for various V2x2 quads here, most of which have the settings for switching on the lights and flips. Lights you just change the value of channel 5 (as stated before); some have done it with a switch, some with a trim button.
Flips are a bit trickier for some 2x2 because you need to be in at least 80% or 100% mode, then enable flips, then you can flip by quickly moving your ele or ail in the direction you want to flip. For my Devo7e, I use SW B to set the rate (60/80/100), then FMODE1 to enable flips. Despite the somewhat unexpected behavior on lower voltage, this quad is really a lot fun to flip.
3) My V272 always acts weird well before I have low voltage or the lights blink I will land as soon as I seen any signs of control loss and I time my flights to stay under 3:30.
13 Jan 2015 19:38 #27662 by alex367
Replied by alex367 on topic Some Problems with bind and Configurate
Thanks for the tips.
I put the log on PPM and it works very well on the simulator, Thank you.
The other things I have not yet tested.
Time to create page: 0.186 seconds
