NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
- lahiru4216
10 May 2015 06:59 - 10 May 2015 07:01 #32330
by lahiru4216
<<<<<<<<Fly Harder For More Fun>>>>>>>
NEED HELP FOR REPLACING DEVO 7E STOCK MODULE was created by lahiru4216
I have damaged my devo 7e stock module.I have attached some pics of it.I have no idea what to do ?
1. Can i replace Devo 7e stock module with a1705 module ?
2. IF it doesn't what to do ?
{THANKS FOR ANY REPLY]
Last edit: 10 May 2015 07:01 by lahiru4216.
10 May 2015 08:03 #32331
Replied by mwm on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
No, you can't replace the stock module with the A7105. They are completely different things.
If you check the wiki ModuleList , you'll find links to three different CYRF6936 modules. Any of those should work. The first one is used in the Devo 6/8/10/12s, and while it won't plug into the 7e board, I believe it has been wired in successfully. Neither of the other two will plug in directly either, but they might be less expensive or smaller.
In the future, please only post once, and give people a day or two to answer.
- aMax
10 May 2015 13:53 #32346
by aMax
Replied by aMax on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
Where is the second post..? ...... refering to that....
In case the protective coating of the traces is not physically damaged, your module can be rescued by a person with soldering skills.
There are some shorts now. Removing the solder blob plus some of these solder splashes and restarting the work with a short wire will certainly help.
- lahiru4216
11 May 2015 06:34 #32378
by lahiru4216
Replied by lahiru4216 on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
Thanks mwm .sorry for the second post.i delete it succesfully.
- lahiru4216
11 May 2015 06:36 #32379
by lahiru4216
thanks amax ,i will try to give it for repair center.
any link for another module to replace cyrf 6936 module ?
- SadSack
11 May 2015 08:59 #32381
by SadSack
Replied by SadSack on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
www.banggood.com/Walkera-WK-DEVO-S-MOD-U...8S-12S-p-922596.html
That's as good as it gets, hope that helps.
- aMax
11 May 2015 09:29 #32384
by aMax
Devo7e with fullsize RF module.
... www.hacksmods.com/category/devo-2/lahiru4216 wrote: thanks amax ,i will try to give it for repair center.
- lahiru4216
12 May 2015 12:48 #32441
by lahiru4216
Thanks sadsack,the module restock on 13th May , I will looking for it.
- lahiru4216
16 May 2015 15:05 #32646
by lahiru4216
problem solved i ordered walkera devo s -mod module,I will try it ...
- Dante1
30 Jan 2016 17:28 #42425
by Dante1
Replied by Dante1 on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
Did you every get the module replaced? I am in the process of doing the same. Do you have any info on replacing the module?lahiru4216 wrote:
- RedSleds
30 Jan 2016 17:47 #42426
by RedSleds
Replied by RedSleds on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
He doesn't appear to be very active on the site.
A PM might be a better way to find out from him.
- Dante1
30 Jan 2016 17:55 #42427
by Dante1
ThanksRedSleds wrote: He doesn't appear to be very active on the site.
- lahiru4216
08 Mar 2016 15:14 #44264
by lahiru4216
Sorry Everyone for late reply.i got some problems with "account log in".i replaced stock devo 7e module with devo 8s 12s module>>>
- lahiru4216
08 Mar 2016 15:17 #44265
by lahiru4216
www.hacksmods.com/2014/10/wk-devo-s-mod-module-for-devo7e/
HERE IS THE LINK FOR REPLACING 7E MODULE..
- Mr Magik
10 Sep 2016 11:39 #53743
by Mr Magik
Replied by Mr Magik on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
Hi there, I have a devo 7e transmitter and I just bought a 8s module and the people who sold it to me are telling me that you can not replace the devo 7e module with an 8s. How did you find out how to do is there any links to a video or info on how to do the install?
Also just want to confirm that this 8 module does definitely work in the devo 7e?
- jmcclurg
12 Sep 2016 03:25 #53804
by jmcclurg
Replied by jmcclurg on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
Daryoon has a tutorial here:
www.hacksmods.com/2014/10/wk-devo-s-mod-...for-devo7e/#comments
Time to create page: 0.057 seconds
- NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
