Low volume problem
- Landin
13 May 2015 03:54 #32479
by Landin
Low volume problem was created by Landin
Im I the only one that having problem with the buzzer volume?
Its so quiet that I almost cant hear it 1m away in a quiet room.
The problem is when flying fpv and the radio is warning me for something and I cant hear it.
A version bugg, or do I have to buy a new buzzer?
And yes, the volume is set to 10.
- Landin
14 May 2015 20:51 #32582
by Landin
Replied by Landin on topic Low volume problem
41 views and no one of you have a devo10 and can reply if you having the same issue please?
14 May 2015 21:09 #32586
Replied by FDR on topic Low volume problem
I have a DEVO 8, and yes it is much quieter than it was with the original devention fw, but I wouldn't say I can't hear it.
Try to play with the sound frequency. The percieved volume heavily depends on it...
- Landin
15 May 2015 10:48 #32615
by Landin
Thanx! I will try that!
- Landin
18 May 2015 06:31 #32723
by Landin
So. Finaly I fixed it, in the Sound.ini file the volume was set to 30 of 100.. so even if having the volume set to 10 in the radio gui, the volume was only 30% of that.
- ronzer
18 May 2015 18:04 #32748
by ronzer
Replied by ronzer on topic Low volume problem
I changed mine to 100 and cant see a difference, I still cant here mine.
18 May 2015 19:11 #32749
Replied by mwm on topic Low volume problem
I noticed that on mine, setting the volume to 10 in the Tx configuration causes it to be nearly inaudible. Setting it to 9 is much louder.
- Landin
18 May 2015 20:27 #32751
by Landin
On mine, when set it to 9 in the TX, I could not hear it, but when set it to 10 and 100 in the sound.ini file, it sounds nice =)
- RedSleds
18 May 2015 20:48 #32752
by RedSleds
Replied by RedSleds on topic Low volume problem
Dittomwm wrote: I noticed that on mine, setting the volume to 10 in the Tx configuration causes it to be nearly inaudible. Setting it to 9 is much louder.
Time to create page: 0.093 seconds
- Low volume problem
