How can I use my Devo 8s with a simulator?
- ronzer
26 Jun 2015 19:41 #34697
by ronzer
How can I use my Devo 8s with a simulator? was created by ronzer
How can I use my Devo 8s with a simulator? anybody done this? Its a free simulator I am trying to use.
- aMax
26 Jun 2015 20:48 #34700
by aMax
Replied by aMax on topic How can I use my Devo 8s with a simulator?
With all deviated Devos you can use a sim that accepts an USB HID device.
- ronzer
26 Jun 2015 21:15 #34703
by ronzer
Replied by ronzer on topic How can I use my Devo 8s with a simulator?
Is there away I turn it on in my radio?
- greenfly
26 Jun 2015 21:21 #34704
by greenfly
Replied by greenfly on topic How can I use my Devo 8s with a simulator?
You enable it by creating a model with 'USBHID' as the protocol. Then when you select that model, you can plug it into you USB port and it will appear as a joystick to the computer.
http://www.deviationtx.com/manuals/html-devo8/ch_protocols.html#protocol-usbhid
- ronzer
26 Jun 2015 21:50 #34705
by ronzer
Thanks Thats what I needed.greenfly wrote: You enable it by creating a model with 'USBHID' as the protocol. Then when you select that model, you can plug it into you USB port and it will appear as a joystick to the computer.
27 Jun 2015 00:28 #34711
Replied by mwm on topic How can I use my Devo 8s with a simulator?
Or if you've got a sim that came with a trainer->USB adapter, you can set the protocol to PPM, and then use that just like any other Tx.
- Thomas.Heiss
27 Jun 2015 09:46 #34737
by Thomas.Heiss
Replied by Thomas.Heiss on topic How can I use my Devo 8s with a simulator?
Realflight V6.5 works fine in PPM mode. I had the Devo 10 connected to the Realflight elite interlink controller.
I could even use it with Heli-x V6 (interlink) with the latest graphic drivers, which turned off all the rendering problems.
The Devo 10 just works fine with my older Reflex XTR V5.03 version (blue big dongle) in PPM mode.
Even with the standard Graupner USB dongle cable adapter where I last soldered a mono plug onto (Stereo plug before with two cables).
This is funny that Devo 10 in PPM and that cablebecause it had failed with Spektrum DX8 transmitter before.
Reflex V5.03 blue dongles seemed not to be well compatible with Spektrum transmitters for an unkown reason?!?
Reflex had introduced red ( 5.05 versions) dongles and newer small blue flat dongles in V5.06.
Seems that is the way how Simwerk fixed the avobe V5.03 dongle / cable problems.
So just get a Walkera Devo sender and you are fine
Time to create page: 0.038 seconds
- How can I use my Devo 8s with a simulator?
