Padding at the end of models .ini files
13 Sep 2015 15:35 - 13 Sep 2015 15:42 #37716 by ethernode
Padding at the end of models .ini files was created by ethernode
Newbie here; i noticed that there is some zero padding in the end of ini files that is apparently being added by deviationtx itself when editing a model; while i don't really care, it makes gedit not happy at all (trying to guess the character encoding of this null padding). Out of curiosity, why is it happening ? Is there any way to avoid it ?
$ hexdump -C inductrix_indoor.ini
00000000  6e 61 6d 65 3d 49 6e 64  75 63 74 72 69 78 20 69  |name=Inductrix i|
00000010  6e 64 6f 6f 72 0a 6d 69  78 65 72 6d 6f 64 65 3d  |ndoor.mixermode=|
00000020  41 64 76 61 6e 63 65 64  0a 69 63 6f 6e 3d 49 4e  |Advanced.icon=IN|
00000030  44 55 43 54 2e 42 4d 50  0a 5b 72 61 64 69 6f 5d  |DUCT.BMP.[radio]|
00000040  0a 70 72 6f 74 6f 63 6f  6c 3d 44 53 4d 58 0a 6e  |.protocol=DSMX.n|
00000050  75 6d 5f 63 68 61 6e 6e  65 6c 73 3d 36 0a 74 78  |um_channels=6.tx|
00000060  5f 70 6f 77 65 72 3d 31  35 30 6d 57 0a 0a 5b 70  |_power=150mW..[p|
00000070  72 6f 74 6f 63 6f 6c 5f  6f 70 74 73 5d 0a 54 65  |rotocol_opts].Te|
00000670  54 78 50 6f 77 65 72 3d  31 30 32 2c 37 0a 71 75  |TxPower=102,7.qu|
00000680  69 63 6b 70 61 67 65 31  3d 43 68 61 6e 6e 65 6c  |ickpage1=Channel|
00000690  20 6d 6f 6e 69 74 6f 72  0a 00 00 00 00 00 00 00  | monitor........|
000006a0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00003000  00 00 00 00 00 00 00 00  00 0a 00 00 00 00 00 00  |................|
00003010  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00003ff0  00 00 00 00 00 00 00 00  00 00 00 00 00 0a 00 0a  |................|
00004000
Last edit: 13 Sep 2015 15:42 by ethernode.
14 Sep 2015 16:13 #37764 by greenfly
Replied by greenfly on topic Padding at the end of models .ini files
This is normal.
I could not find a way for Gedit to open them directly without the warning. It depends on the editor... Notepad++ in Windows does not have a problem with the trailing nulls.
I actually solved the issue with my utility here . It trims the nulls prior to opening the INI file.
15 Sep 2015 10:26 #37779 by ethernode
Replied by ethernode on topic Padding at the end of models .ini files
Okay thanks.
Time to create page: 0.054 seconds
