Permanent timer value stored in milliseconds
- ethernode
13 Sep 2015 15:58 #37718
by ethernode
Permanent timer value stored in milliseconds was created by ethernode
I have a Devo 7E running deviationtx 4.0.1.
I have an issue with permanent timers, which i would like to use to count how many flight hours ; i defined a timer3 into one of my ini to permanent timer type; from my understanding, when resetting it (zeroing it), the ini file section does not contain any value.
Running the throttle for 60 seconds, opening the ini shows that this value seems to be stored in milliseconds:
Out of curiosity, why is this value not stored in seconds (while countdowns seem to be in seconds) ? A permanent timer would rather be used for measuring total flight times, right, so using seconds would allow longer lifetime values, isn't it ?
Also, is there any way to share a permanent timer between models (e.g. 2 ini, one for indoor, one for outdoor, sharing the same permanent timer value) ?
[timer3]
type=permanent
src=THRRunning the throttle for 60 seconds, opening the ini shows that this value seems to be stored in milliseconds:
[timer3]
type=permanent
src=THR
val=60500Out of curiosity, why is this value not stored in seconds (while countdowns seem to be in seconds) ? A permanent timer would rather be used for measuring total flight times, right, so using seconds would allow longer lifetime values, isn't it ?
13 Sep 2015 19:46 #37730
Replied by mwm on topic Permanent timer value stored in milliseconds
Even with milliseconds, timers still count over 7 weeks. That seems like quite a lifetime, so why make the code for timers more complicated to make it longer?
No, there's no way to share a timer.
- ethernode
14 Sep 2015 10:33 #37752
by ethernode
Replied by ethernode on topic Permanent timer value stored in milliseconds
Sounds good, thanks. At least i'm not good enough to keep a model aliave for 7 weeks of flight time
Time to create page: 0.115 seconds
- Permanent timer value stored in milliseconds
