Module install not working?
- Shawzie
17 Oct 2015 04:46 #38950
by Shawzie
Module install not working? was created by Shawzie
Can someone look over this and see if im doing something wrong here please?? I installed the NRF24L01 module and then went into my tx file, switched the none on the module to A14 and put 1 for the PA. Im not getting any change, its not seeing the module??? I also switched the main module from B12 to none just to see if it changed but nothing changed after that either??? What am i missing?
current_model=5
language=0
music_shutdown=1
mode=2
brightness=10
contrast=5
volume=10
vibration=0
power_alarm=0
batt_alarm=4300
batt_critical=3800
batt_warning_interval=10
splash_delay=35
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=None
has_pa-a7105=0
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A14
has_pa-nrf24l01=1
[calibrate1]
max=3790
min=428
zero=2103
[calibrate2]
max=3696
current_model=5
language=0
music_shutdown=1
mode=2
brightness=10
contrast=5
volume=10
vibration=0
power_alarm=0
batt_alarm=4300
batt_critical=3800
splash_delay=35
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=None
has_pa-a7105=0
enable-cc2500=None
has_pa-cc2500=0
enable-nrf24l01=A14
has_pa-nrf24l01=1
[calibrate1]
max=3790
min=428
zero=2103
[calibrate2]
max=3696
- Shawzie
17 Oct 2015 05:13 #38951
by Shawzie
Replied by Shawzie on topic Module install not working?
figured it out!!! Thanks.
- Arnold
17 Oct 2015 20:24 #38982
by Arnold
Replied by Arnold on topic Module install not working?
Care to share what you did to fix it? I have yet to do this and want to watch for pitfalls.
- Shawzie
18 Oct 2015 00:49 #39001
by Shawzie
Sure thing, it's silly though, just wasn't saving the changes on notepad++, when I looked at it in normal notepad I noticed it didn't change to A13, it still said none.
Time to create page: 0.068 seconds
- Module install not working?
