A7105 module strain relief
20 Nov 2015 15:21 #40240 by mwm
A7105 module strain relief was created by mwm
Well, the RMA antenna connected to my A7105 came off. Again. Seems to happen every time I have to muck about inside the radio. Hot glue doesn't seem to help.
Anyone got a solution for strain relief?
I'm thinking about trying liquid electrical tape, or maybe some instamoprh or sugru along with something to hold in it in place - like that liquid tape again. Anyone got any comments on either of those ideas?
20 Nov 2015 19:49 - 20 Nov 2015 19:50 #40246 by SadSack
Replied by SadSack on topic A7105 module strain relief
Hi.
Could you post a pic or two :-)
I honestly wouldn't use any form of glue. Makes working on it later a total nightmare!
Last edit: 20 Nov 2015 19:50 by SadSack.
20 Nov 2015 20:06 #40247 by mwm
Replied by mwm on topic A7105 module strain relief
A pic or two of what? My A7105 with the antenna coming off?
Hot glue comes off easy - that's why I tried it. Unfortunately, it also isn't working well.
The other two choices aren't glues. Liquid electrical tape is great stuff for tight spaces and scrapes off, but I'm not sure how well it would work here. Instamorph is malleable plastic, and this would be my first project with it.
20 Nov 2015 20:43 #40251 by Deal57
Replied by Deal57 on topic A7105 module strain relief
It seems like the A7105 antenna problem is that the ones from BG (and other sellers) have a wire antenna soldered to the board as opposed to an IPX (U.fl) coaxial female SMT connector. It's probably cheaper just to use the wire because most users don't want or need the antenna connector. Done correctly the connection will be very reliable and resistant to abuse.
I would prefer to have an option and I've ordered a few connectors for my boards just because. The solder points although small are right on the board edge, so it doesn't seem to be a risky job.
20 Nov 2015 21:03 #40252 by mwm
Can you provide a link to the connectors you ordered? I think a lot of options showed up on ebay, but I'd rather not wait a month to find out I ordered the wrong thing!
This is a case where the JoySway module would be an improvement. No connector and it won't work with the MM, but it's at least got a long enough antenna lead that you can position the antenna inside the Tx with some freedom.
20 Nov 2015 21:15 - 20 Nov 2015 21:26 #40254 by RedSleds
Replied by RedSleds on topic A7105 module strain relief
Here is what I did
www.amazon.com/gp/product/B00CXOC5Z4
It's available with free shipping if you have an Amazon PRIME membership.
Last edit: 20 Nov 2015 21:26 by RedSleds.
20 Nov 2015 21:30 #40256 by Deal57
My ebay RF vendor of choice is Wifi_Expert (coaxrf.com). They charge about $10 for 10... lesser quantities seem to end up costing nearly $10 anyway. PM me if you want just one or two, cause I'm not gonna use them all for a long time!
23 Nov 2015 02:55 #40303 by Richard96816
Replied by Richard96816 on topic A7105 module strain relief
If antenna coax is what you're needing to secure, and it's long enough, you can probably improve strength by running it along a clean surface on the module for a short distance. Then your hot glue, or whatever you decide to use should have more 'purchase' along that run. Try to have the length of attached cable point in the normal direction of strain to increase its staying power. You may have to make a loop of sorts to make this happen. Assuming you have enough cable.
Point source connects can be problematic. Especially if there's no through-hole.
With enough length of purchase even a weak glue can stand up to a fair amount of strain.
23 Nov 2015 23:54 #40330 by mwm
Well, for the record, Instamorph doesn't work. Not without extra tape/glue/something to hold it in place. IPX connectors on order.
Thanks to all for the help.
Time to create page: 0.113 seconds
