devo8s, rudd switch disables the stick channels?
- dawsonmobley
23 Dec 2015 01:21 - 23 Dec 2015 01:24 #41094
by dawsonmobley
devo8s, rudd switch disables the stick channels? was created by dawsonmobley
I am trying to use the rudd switch to arm/disarm my quad however when I switch it to arm, the quad does arm but my sticks are then locked out? when I disarm they work again (in the cleanflight rx tab as well as in the radios stick section)
I have this same setup on another quad and it works fine and I can't find any difference between the two profiles on my tx (devo8s running deviation).
I moved the arm/disarm switch from the rudd switch to another switch and it works as it should...I'm pretty sure it's a setting on my tx that is causing the rudd switch to disable channels 1-4 on this profile when it's in the up position?
I've gone through every screen on my radio and can't figure out how to disable that behavior???
Last edit: 23 Dec 2015 01:24 by dawsonmobley.
- dawsonmobley
23 Dec 2015 04:28 #41095
by dawsonmobley
Replied by dawsonmobley on topic devo8s, rudd switch disables the stick channels?
Nevermind, I figured it out....I had the rudd1 set as the trainer switch a long time ago and forgot about it....channels 1 thru 4 are the channels that I had set for the slave tx to use
Time to create page: 0.023 seconds
- devo8s, rudd switch disables the stick channels?
