Deviation compatible brushed FC/RX w/ telemetry?
- mellowvision
13 Feb 2016 04:47 #43075
by mellowvision
Deviation compatible brushed FC/RX w/ telemetry? was created by mellowvision
I really love building tiny brushed quads to fly with my Devo 6s. One of the things I like about flying builds using the hubsan x4 fc, is that it provides battery voltage telemetry to the devo.
This seems unique among the brushed flight controllers I've come across.
The telemetry is a nice thing once you're used to having it. I bring my batteries in at 3.8v all the time. But, I don't want to fly hubsan FC... would really prefer to be flying something programmable.
Are there other micro fc / rx pairs that I should look at that would get battery voltage to my devo?
Alternately, do you know of any brushed FC's that would support OSD telemtry via minimosd or similar? that would be fun to mess with as well.
- RoGuE_StreaK
13 Feb 2016 05:24 #43077
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Deviation compatible brushed FC/RX w/ telemetry?
I think the X4 fc is flashable with
BradWii
- mellowvision
13 Feb 2016 05:58 #43078
by mellowvision
Replied by mellowvision on topic Deviation compatible brushed FC/RX w/ telemetry?
it does look like it's flash-able, but that might be a lot of effort for a so-so FC. and would it still send telemetry data after being flashed?
also, I found this thread that is very interesting, sounds like the multiflight.co.uk guy is working on a micro size vtx with built in OSD that mounts up directly to a multiflight nano board. it's not going to be out for a couple of months still... community.micro-motor-warehouse.com/t/osd-osd-for-micros/133
- camousse
20 Feb 2016 09:49 #43354
by camousse
Replied by camousse on topic Deviation compatible brushed FC/RX w/ telemetry?
you can build something with that :
www.goodluckbuy.com/micro-quadcopter-fli...ensor-stm32f103.html
you will need to find a receiver with telemetry (i only know frsky with telemetry, but you will need a cc2500, or maybe a walkera ?).
you can also go for a dsm2 sat, and add a bluetooth (a light one) to have telemetry (and the hability to tune pid) on your android phone
- saintz
02 Mar 2016 18:09 #43985
by saintz
Replied by saintz on topic Deviation compatible brushed FC/RX w/ telemetry?
The user manual lists available telemetry for each protocol. Unfortunately Hubsan is the only toy FC listed that supports it. I'm going to assume that everything NRF24 based does not support telemetry (v2x2, Bayang, Syma, etc.). The Hubsan uses A7105.
You might check if the U807 supports telemetry. It's A7105 based. It uses a modified FlySky protocol. I doubt it will have telemetry, but it would be my best guess for one that does other than Hubsan.
- camousse
02 Mar 2016 21:39 #43995
by camousse
you can try a a7105 mini brushed, flash it with bradwii with hubsan protocol. But i think there is no voltage sensor connected to cpu so...
- dc59
03 Mar 2016 00:00 - 03 Mar 2016 00:02 #44001
by dc59
Replied by dc59 on topic Deviation compatible brushed FC/RX w/ telemetry?
It's also a good choice for you.
www.hobbyking.com/hobbyking/store/__8650...t_Control_Board.html
or
www.banggood.com/Micro-Scisky-32bits-Bru...pters-p-1002341.html
DSM2/DSMX
Cleanflight or Baseflight compatible
or
DSM2/DSMX
Last edit: 03 Mar 2016 00:02 by dc59.
- Fernandez
03 Mar 2016 08:11 #44014
by Fernandez
Replied by Fernandez on topic Deviation compatible brushed FC/RX w/ telemetry?
I can confirm that my walkera Super CP also correctly transmits pack voltage to Devo 7e.
- Deviation compatible brushed FC/RX w/ telemetry?
