Looking for upgrade stock module cyrf6936 for 7E
- C0ckpitvue 777
26 Feb 2016 14:14 #43670
by C0ckpitvue 777
Looking for upgrade stock module cyrf6936 for 7E was created by C0ckpitvue 777
Does anyone know of a reliable retailer who sells quality modules?I'm trying to upgrade my devo 7e with an 8s cyrf6936 module.Also looking for a step by step tutorial to do this mod.Links or info will be greatly appreciated.
- grnd flyr
26 Feb 2016 14:23 #43671
by grnd flyr
Replied by grnd flyr on topic Looking for upgrade stock module cyrf6936 for 7E
I got a few of them from Bangood at the time and it looks like they are not available there atm... have seen them recommended here before tho:
WALKERA (WK-DEVO-S-MOD) DEVO 8 or 12 to DEVO 8S or 12S Upgrade Module
www.ehirobo.com/walkera-wk-devo-s-mod-de...-upgrade-module.html
...says they are in stock...
- grnd flyr
26 Feb 2016 15:17 #43677
by grnd flyr
File this under FWIW k... you're probably better than me with soldering (I think most folks are...
If you're inexperienced or don't have much background experience with desoldering, there is a real risk in tearing/ripping the soldering pads right off of your Devo. I've done three of the WK-DEVO-S-MOD modules and that's exactly what happened to one of mine... snarg.
There is something that will help, and for me, worked like magic in removing the original CYRF without damaging anything. (also works fantastically for removing pins from say a new Nrf module): ChipQuick:
ChipQuik SMD1 Leaded Low Temperature Removal Kit
www.amazon.com/ChipQuik-SMD1-Leaded-Temp...emoval/dp/B0019UZP7I
EEVblog #437 - Removing SMD Parts with ChipQuik
...that, and using a little larger tip on the soldering iron which will allow you to get in there and out - quick:
Hakko T18D16P Tip for Fx-888 Station, 1.6mm
www.amazon.com/Hakko-T18D16P-Fx-888-Station-1-6mm/dp/B004OR9BV4
Hakko T18-DL2 Tip Chisel 2 x 22.5mm for Hakko FX-888/FX-8801
www.amazon.com/Hakko-T18-DL2-Chisel-22-5...X-8801/dp/B00762AHHQ
Like I said, with my hamfisted soldering/desoldering, ChipQuick made all the difference/made it easy! The solder that comes on the stock CYRF module is I think, non-leaded or whatever, and takes a higher temp on your iron to work with. I love this stuff:
Kester 44 Rosin Core Solder 63/37 .020 1 lb. Spool
www.amazon.com/Kester-Rosin-Core-Solder-Spool/dp/B00068IJWC
hth...
hth...
- C0ckpitvue 777
26 Feb 2016 21:48 #43717
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Looking for upgrade stock module cyrf6936 for 7E
Thanks for the feedback,do you got all 4 modules installed in your devo?
- grnd flyr
26 Feb 2016 23:28 #43724
by grnd flyr
You're welcome, nope just WK-DEVO-S-MOD, A7105 & Nrf. I have a few of the cc2500 modules that I originally planned on using on the bigger/faster quads with a Lemon or Orange, but ended up getting a Taranis so have not used those. Yet...
Time to create page: 0.027 seconds
- Looking for upgrade stock module cyrf6936 for 7E
