Devo10 RF module dead?
01 Mar 2016 03:03 #43920 by Ztiep
Devo10 RF module dead? was created by Ztiep
So the issue I am having is that I have very little range with my Devo 10 100mw white version. I have tried everything, tried about 5 different antennas soldered it directly to the transmitter board. Everything!
It seems as though something is up with the transmitter, I have tried 3 different receivers all the same, taken of the antenna entirely same range. Im sure it is something with the RF Module no idea what. It can still send commands but it is very weak of a signal. I don't think the entire RF module is bad, just something on it.
Please Help.
01 Mar 2016 05:14 #43923 by FDR
Replied by FDR on topic Devo10 RF module dead?
If you have ever turned it on without an antenna, you could fry the power amplifier.
If you have smd soldering skills, you can try to replace it, or you can buy a new RF module...
01 Mar 2016 07:33 #43930 by Ztiep
Replied by Ztiep on topic Devo10 RF module dead?
I actually do have some smd soldering skills, but maybe just ordering a new RF module. Does it also help though that the RF module still gets warm when plugged in. Any places on where to get the same module for it? Every place I look at says that is only for the 8s and 12 devo.
01 Mar 2016 07:51 #43933 by mwm
Replied by mwm on topic Devo10 RF module dead?
The 10, 6s and 8s all use the same RF module. The 7e is different. Not sure about the 12s.
01 Mar 2016 07:57 #43934 by Ztiep
so this should work fine www.ehirobo.com/walkera-wk-devo-s-mod-de...-upgrade-module.html . Do you happen to know any other sources for this part?
01 Mar 2016 09:00 #43937 by FDR
The other sources are usually out of stock for a long time.
It used to be cheaper, but last time I bought it from them too for $20...
01 Mar 2016 11:12 #43941 by TomPeer
Replied by TomPeer on topic Devo10 RF module dead?
mwm wrote: The 10, 6s and 8s all use the same RF module. The 7e is different. Not sure about the 12s.
12s is also the same as 10 and 8s.
20 Mar 2016 12:30 #44866 by lahiru4216
Replied by lahiru4216 on topic Devo10 RF module dead?
<<<<<<<<Fly Harder For More Fun>>>>>>>
20 Mar 2016 13:24 #44867 by FDR
Walkeraonline is not the official Walkera. It is the same as eHirobo:
www.walkeraonline.com/about-us.html
www.ehirobo.com/about-us.html
They have a lot of webshops with different domain names...
20 Mar 2016 14:48 #44868 by lahiru4216
thanks "FDR".i was wrong.
Time to create page: 0.293 seconds
