ER250 receiver recommendation
- ursus69
30 Mar 2016 18:54 #45455
by ursus69
ER250 receiver recommendation was created by ursus69
Hi all!
I have a Devo7e with modules and I will have a Eachine Racer 250 soon. What RX recommend me to use with?
A friend can leave me a D4R-II or X4Rsb....Or what RX recommends to buy??
31 Mar 2016 20:37 #45510
Replied by mwm on topic ER250 receiver recommendation
Depends on your FC. Best bet (for now) if your FC can do SBUS is the new OrangeRx modules with sbus support. They use the DSM protocol, no extra rf module required. If it doesn't do SBUS, then the D4R-II is probably best, as the FrSk X protocol hasn't been implemented. They use FrSky protocol, and need a CC2500. The X series receivers can do SBUS, but we don't have support for them in the nightly build yet (soon, I hope). The non-EU ones can do the D series protocol, but telemetry is odd, and that may also break SBUS (unlikely, but who knows) so I'd stay with the D series. They'll also require a CC2500.
- ursus69
01 Apr 2016 12:47 - 01 Apr 2016 12:57 #45561
by ursus69
Replied by ursus69 on topic ER250 receiver recommendation
Last edit: 01 Apr 2016 12:57 by ursus69.
- aMax
01 Apr 2016 13:08 - 01 Apr 2016 18:42 #45563
by aMax
Replied by aMax on topic ER250 receiver recommendation
Have a look at medilic's firmware and the F802 from BG.( if using leanfight).....cleanflight
www.rcgroups.com/forums/showpost.php?p=33046356&postcount=1217
PWM,PPM,SBUS (non inverted), telemety and RSSI via PWM or with SBUS on channel 9 to the flightcontroller (for an OSD)...
Edit: . not a 1. April joke, just a typo...
...lol
Last edit: 01 Apr 2016 18:42 by aMax.
- ursus69
01 Apr 2016 14:39 #45569
by ursus69
Thanks aMax! I will take a look!
01 Apr 2016 20:51 #45597
I believe LemonRx is independent, where OrangeRx is a Hobby King brand. They did their own implementations of the DSM2/DSMX protocols (possibly borrowed from deviation but they aren't admitting it). Early Rx's from both had problems and are best avoided. It's not clear the LemonRx ones are past that yet. I'm not sure they have SBus output, for that matter.
The OrangeRx Rx of choice seems to the be 620X Sbus version - if they're in stock.
- ursus69
01 Apr 2016 22:31 - 02 Apr 2016 09:47 #45602
by ursus69
This ones?
www.hobbyking.com/hobbyking/store/__9061...B_EU_Warehouse_.html
www.hobbyking.com/hobbyking/store/__9062...B_EU_Warehouse_.html
Or this? (CPPM)
www.hobbyking.com/hobbyking/store/__9060...P_EU_Warehouse_.html
Where I can find a manual of this Rx's? Or how to configure...
Thanks again mwm!!
Or this? (CPPM)
Thanks again mwm!!
Last edit: 02 Apr 2016 09:47 by ursus69.
02 Apr 2016 21:43 - 02 Apr 2016 21:45 #45673
The first one. The 6 and 7 channel versions both have 12 channels via SBus, so the only thing missing is one possible PWM channel and a little weight. The CPPM version is only 9 channels (and I'd be careful if you wanted to use all 9 because of the framing issues I mentioned). The FrSky D-series receivers are generally better if you want CPPM - they have better range, their telemetry is full range rather than 20% of the control range, and they weigh less than half what the orangeRx receivers weigh. They do require a CC2500 and don't have the option of getting both CPPM and PWM output.
Edit: forgot to add that you can find the manuals for most HK products in the files section of the version from the international warehouse! I'd check there.
Last edit: 02 Apr 2016 21:45 by mwm.
- ursus69
03 Apr 2016 18:53 #45730
by ursus69
For the same price...better the 720X??
03 Apr 2016 19:34 #45731
The 720X is bigger and heavier than the 620X, but has one more channel of PWM output. With 12 channels of SBUS, the extra PWM channel seems unlikely to be used, but smaller and lighter on an aircraft is almost always a win.
ursus69 wrote: For the same price...better the 720X??
- ursus69
03 Apr 2016 19:47 - 03 Apr 2016 19:51 #45733
by ursus69
Received
Thanks again mwm!
Edit: hobbyking web:
R620X V2 Dimensions: 49 x 25 x 15.5mm Weight: 12.5g
R720X V2 Dimensions: 49 x 25 x 15.5mm Weight: 12.5g
R620X V2 CPPM Dimensions: 49 x 22 x 15.5mm Weight: 12.2g
Thanks again mwm!
Last edit: 03 Apr 2016 19:51 by ursus69.
Time to create page: 0.218 seconds
- ER250 receiver recommendation
