Devo 10 3 modules
- SirDomsen
05 Jun 2016 21:08 #49997
by SirDomsen
Devo 10 3 modules was created by SirDomsen
Short question: Is it possible or useable to add 3 modules (plus CYRF 4 then) to a Devo 10? If yes, what changes are needed as there is no pin left in pin assignment for the 3rd module in hardware.ini?
Domsen
Domsen
- HappyHarry
05 Jun 2016 21:22 #49999
by HappyHarry
Replied by HappyHarry on topic Devo 10 3 modules
yes, read here >>
www.deviationtx.com/forum/7-development/...4in1-rf-module#43726
- Arnold
05 Jun 2016 21:25 - 05 Jun 2016 21:28 #50001
by Arnold
See the thread about the 3-in-1 Module and look at post #43726.
www.deviationtx.com/forum/7-development/...-module?limitstart=0
I believe all the info you need is contained in that post.
<Edit> Oops! Only a few minutes behind HH, who is always on the ball!
Replied by Arnold on topic Devo 10 3 modules
Yes Sir, it has been proven that pad B7 on the D10 is a good connection for the 3rd module.SirDomsen wrote: ... Is it possible or useable to add 3 modules (plus CYRF 4 then) to a Devo 10? If yes, what changes are needed as there is no pin left in pin assignment for the 3rd module in hardware.ini?
Last edit: 05 Jun 2016 21:28 by Arnold.
- RedSleds
05 Jun 2016 23:30 #50008
by RedSleds
Replied by RedSleds on topic Devo 10 3 modules
...or, just use the OSH Park multi-module PCB with a CC2500, nRF24L1, and A7105 transceivers, and a ATtiny24 microcontroller for switching. The DEVO 10 has the full power CYRF transceiver already in it.
It is a more sorted out solution than the 3-in-1 and 4-in1 is, at least in my opinion. Not to say that the 3-in-1 and 4-in1 modules won't eventually be just as good, after they get all of kinks worked out, such as, what revision board are you actually going to get from a vendor, LNA issues, range issues, etc. . But, there is a lot of effort in getting it to a point of being a good solution. Though, I still think the OSH Park Multi-Module method is the solution with the best results at this time. Just my opinion, YMMV.
- SirDomsen
05 Jun 2016 23:47 - 05 Jun 2016 23:49 #50009
by SirDomsen
Replied by SirDomsen on topic Devo 10 3 modules
Thanks, men! Now I recall that I already stumbled across that thread you mentioned but forgot about it. I only had the feeling that I read that this is possible. Only Comment in the last module (CC2500 in my case, it already has a nrf and a71) and assign pin? Is it possible to assign every MCU pin that way?
Last edit: 05 Jun 2016 23:49 by SirDomsen.
09 Jun 2016 20:59 #50273
Replied by mwm on topic Devo 10 3 modules
Well, you could in theory assign every mcu pin that way, but you want to avoid any that are already in use.
Time to create page: 0.074 seconds
- Devo 10 3 modules
