devo 7e fmod
23 Aug 2016 20:38 #53049 by andyroberts176
devo 7e fmod was created by andyroberts176
Newbie question
I have a 7e with deviation 5.0
and cant seem to get the fmod switch assigned to 3 or 6 axis gyro
somebody help it's driving me batty
cheers Andy
  • rjmcewen63
  • rjmcewen63's Avatar
  • I know how to fly, I'm learning not to crash...
11 Sep 2016 03:13 #53778 by rjmcewen63
Replied by rjmcewen63 on topic devo 7e fmod
Heres my Master CP model file. The gyro is controlled thru channel 7. My fmod switch changes it from fmod0 - 50 (gyro 75%) and fmod1 - 0 (gyro 50%). There are some other features you might be interested in. The hold switch engages a "sticky" hold. You must return the throttle channel to minimum before the throttle re-engages. Fmod also changes your pitch and throttle curves for 6d flight. I hope this helps. As always, use this file at your own risk. Always test before flying! Good luck, bro!
_
/_/ _ _
/ \/_/_\_\
Time to create page: 0.077 seconds
