can't save models any more...
- Podflyer
07 Sep 2016 12:10 #53572
by Podflyer
can't save models any more... was created by Podflyer
have a devo 10 running deviation 5.0 saved 3 models but now can't seem to save any more. can some one talk me through the process please.
- Cereal_Killer
07 Sep 2016 13:19 #53574
by Cereal_Killer
Replied by Cereal_Killer on topic can't save models any more...
Your batteries arn't to low are they?
Setup model
SWITCH MODEL FILES
Power off tx.
Check if it saved the new one
Setup model
SWITCH MODEL FILES
Power off tx.
- steadfast4life
14 Sep 2016 05:21 #53852
by steadfast4life
Replied by steadfast4life on topic can't save models any more...
I also had this problem. The problem was I was using a 2s life battery which was far too low in voltage so the tx would power on but I couldn't save anything.
- RRacer
16 Sep 2016 07:05 #53904
by RRacer
Replied by RRacer on topic can't save models any more...
This is what I wrote in another thread about not being able to save when using a 2S lipo:
You need to edit tx.ini, and set batt_critical to a lower value.
I think the default is about 10500 (mV).
Set it to the lower limits of a 2-cell pack, say 7500 (7.5 V), and you should be fine.
batt_critical can not be edited in the tx gui, you have to do it from a computer over USB.
Do not edit with Notepad, use Notepad++ or some other proper editor.
Time to create page: 0.048 seconds
- can't save models any more...
