- General
- General Discussions
- Low range issue only about 15 feet from my 3 in 1 module installed in a devo 7e.
- FJL
22 Oct 2016 11:56 #55270
by FJL
Hi All,
I have a low range issue with my 3 in 1 module purchased from BG around april of this year and recently installed. I am getting 3.28 volts on the modules vcc pin. Is that voltage ok or does it need to be 3.3v or a little higher? What else should I check? My Taranis works fine with the receiver so I know its not that.
Thank you in advance for any suggestions.
Fab
Fab
- HappyHarry
22 Oct 2016 23:13 #55291
by HappyHarry
Replied by HappyHarry on topic Low range issue only about 15 feet from my 3 in 1 module installed in a devo 7e.
the voltage is ok at that level bud, what protocol are you using, and what power level? (I presume it's frsky as you say taranis but the taranis can use other modules including the 4in1). do other recievers on the same protocol have better range? do protocols that use a different rf chip have good range?
- FJL
23 Oct 2016 11:57 #55304
by FJL
Replied by FJL on topic Low range issue only about 15 feet from my 3 in 1 module installed in a devo 7e.
Hi HappyHarry,
Yes, I'm trying to use frisky protocol and tried different power settings but not sure which I should be using. I'll try to connect to a couple other models and check the range. thank you.
- FJL
23 Oct 2016 12:21 #55305
by FJL
I'm getting the same low range using the hubsan protocol also. I forgot to mention I added an antenna mod 5dbi to see if that would help but no go.
- FJL
26 Oct 2016 22:30 - 26 Oct 2016 22:31 #55429
by FJL
I decided to change out the 3 in 1 and installed a CC2500 module and the range is fine with this module. Really only interested in using Frsky and DSMX. Though the 3 in 1 would have been nice.
Last edit: 26 Oct 2016 22:31 by FJL.
- General
Time to create page: 0.031 seconds
