Need help. Motors on wizard spin all the way up...
- Mikewoodkozar
30 Mar 2017 15:31 #60944
by Mikewoodkozar
Need help. Motors on wizard spin all the way up... was created by Mikewoodkozar
So I don't know what's happening but when I see if the radio is working with the props off the motors spin all the way up to full speed when I have the stick at a low throttle. I can just leave the throttle stick in the low position; just enough to start motors spinning barely. Then I leave the stick in the same position; touch nothing else and they start quickly revving all the way up.
I'm using a Devo 10 with deviation 5.0
Orangerx 615x receiver
Eachine wizard x220
Seriously driving me crazy can anyone help please!
Thank you
Eachine wizard x220
Thank you
- Deal57
30 Mar 2017 17:42 #60948
by Deal57
Replied by Deal57 on topic Need help. Motors on wizard spin all the way up...
Are you running Betaflight? Did you make any changes to the stock setting or maybe flash a new version? I don't have the x220, and the brushed settings are probably different, so check out
www.propwashed.com
or RCGroups.com for info on this model. On my F3 Evo brushed controllers I need to turn on motor_stop in the Configuration page. I also have to use the pwm command in the CLI "set motor_pwm_rate = 32000.
- TheSFReader
30 Mar 2017 19:31 #60949
by TheSFReader
Replied by TheSFReader on topic Need help. Motors on wizard spin all the way up...
Mike, As far as I understand, (from some youtube video by Joshua Bardwell, no link, he posts too much to find it again), the spin-up is quite normal : the flight controler tries and accelerate a motor to compensate "some" micro deviation from the attitude he thinks you want. And since there is no propeller, effect on attitude is --->nothing. So he tries and increase the props effect by increasing motor speed, and keeps increasing until he gets an effect...
I suppose you could check if that's the same phenomenon you're having by starting the copter from a slightly differently near horizontal attitude, and most probably it'll be a different motor that starts to spin up...
- Mikewoodkozar
30 Mar 2017 20:11 #60950
by Mikewoodkozar
Replied by Mikewoodkozar on topic Need help. Motors on wizard spin all the way up...
That's totally correct and it was a oh dumb me moment. So thank you very much. I just didn't want to potentially fly it and have it take off.
Then like five min later I went to put it back together and I cooked the rx in he process by stupidly having the wrong pins in the servo lead
Damn and just when I think I had it figured out.
- Need help. Motors on wizard spin all the way up...
