Hall effect gimbals on Devo 10
09 Nov 2017 19:25 #65669 by Fallingwater
Hall effect gimbals on Devo 10 was created by Fallingwater
I feel like I can't possibly let a month pass by without ordering something drone-related from Banggood, and since this time - amazingly enough - I actually don't need any new motors or frames or other spares I've thought of adapting FrSky hall-effect gimbals to my Devo 10. I'm not particularly dissatisfied with the stock gimbals, but being that the Devo is my primary transmitter (and I like DeviationTX so much that if the Devo 10 died tomorrow I'd probably buy another one) I'd like to make it as good as it can possibly be.
Now, I don't have a 3D printer nor any way to fabricate adapters of any kind, so this is going to be a total hack job from a structural and aesthetic point of view. My idea is to cut up the gimbal supports as needed, stick them in and then secure them in place with a ton of two-part epoxy, silicone and/or and melt-glue. I'm not above cutting up the Devo's casing itself if required.
I have two questions before I start the project:
1) are they electrically compatible? I've seen a thread by someone who adapted them for a Devo 12S so I'm assuming yes, but it doesn't hurt to ask.
2) do I get M7 or M9 gimbals? I understand the difference is only in size - which would best fit the Devo 10's casing?
Any thoughts, opinions and/or recommendations are welcome :)
10 Nov 2017 05:00 #65687 by vlad_vy
Replied by vlad_vy on topic Hall effect gimbals on Devo 10
1) M7 or M9 gimbals electrically compatible with any transmitter.
2) Both M7 or M9 gimbals have the same dimensions, but different mounting holes at top plate. I think they can't be fit to other Devo transmitters, at least they can't be fit to Devo 8.
24 Nov 2017 06:58 #66115 by Danker16
Replied by Danker16 on topic Hall effect gimbals on Devo 10
someone has to try this!
24 Nov 2017 19:55 #66139 by magic_marty
Replied by magic_marty on topic Hall effect gimbals on Devo 10
Did it on my 12s thanks to richardclli posting this thread and the files to get the parts printed..I just uploaded them to 3dhuds and got them printed for very cheap..
www.deviationtx.com/forum/how-to/7081-in...devo12s?limitstart=0
04 Dec 2017 20:07 #66336 by sv650s
Replied by sv650s on topic Hall effect gimbals on Devo 10
I have made this mod and i can say it's a great mod !
Just need to turn of 180° the magnets of throttle and elevator (i'm in mode 1)
05 Dec 2017 02:11 #66343 by Fallingwater
Replied by Fallingwater on topic Hall effect gimbals on Devo 10
Would you have pictures of this? I'm very interested. What gimbals did you use? Did everything fit fine?
Also I like the SV650S :D I almost bought one, years ago...
05 Dec 2017 11:59 #66346 by sv650s
15 Jan 2018 18:28 #66891 by Danker16
any further development on the halls for devo 10?
19 Jan 2018 07:21 #66987 by Twilight_Sun
Replied by Twilight_Sun on topic Hall effect gimbals on Devo 10
Here is article (in Russian) how to upgrade stock Devo 10 gimbals with hall sensors. Looks doable, but not very easy
11 Feb 2018 04:27 #67463 by sar315
Replied by sar315 on topic Hall effect gimbals on Devo 10
Sucesefully installed gimbal on Devo 10.
See more details in the thread about Devo 12 - page #5
www.deviationtx.com/forum/how-to/7081-in...vo12s?start=80#67462
Had to trim some plastic from gimbals, and rotate all 4 magnets.
13 Mar 2019 22:23 #73341 by Toolbox1211
Replied by Toolbox1211 on topic Hall effect gimbals on Devo 10
Im currently doing this to my f12e had to make changes to richard's stl file so it fits the different mounts.
I then made a few other changes to make them stiffer then purchased a 3d printer
Time to create page: 0.278 seconds
