What is deviations default channel order?
14 Apr 2018 13:21 #68652 by steadfast4life
What is deviations default channel order? was created by steadfast4life
I'm transferring some old taranis gimbals to my devo 10 and think I got the plugs put in backwards. Can someone tell me the default channel order. Currently it is TEAR. How can I change channel order in the TX? Thanks!
14 Apr 2018 14:22 #68653 by vlad_vy
Replied by vlad_vy on topic What is deviations default channel order?
It depends from used protocol, Devo protocol has EATR channel order.
14 Apr 2018 20:20 #68654 by steadfast4life
Replied by steadfast4life on topic What is deviations default channel order?
I think I can figure out plug placement from your feedback. Thanks!
16 Feb 2019 20:05 #72903 by Ultracon
Replied by Ultracon on topic What is deviations default channel order?
I have a Jumper T8SG Plus using DSMX to run a Hobbyzone Delta Ray with SAFE. I have TEAR set up, channel five on a three position switch for flight mode, and Channel 6 for panic/auto recovery on a two position switch. Problem is, the flight modes and panic switch don't cause any response in the DR. Help on programming the T8SG? Thanks.
Time to create page: 0.271 seconds
