Differential thrust
17 Nov 2018 16:14 #71775 by 1942keremeos
Differential thrust was created by 1942keremeos
I'm trying to mix differential thrust in the Jumper t8sg plus but not having much luck. Has any body done this?
29 Jan 2019 05:25 #72606 by spacecase
Replied by spacecase on topic Differential thrust
I have two 10 amp escs and B1806 motors Iv been thinking of using in a wing with differential thrust.
You would have to go into mixers and use rudder for source (unless you were using ailerons). Hum then two channels for port and starboard throttle.
Ill have to get back, but its a really good question.
29 Jan 2019 20:09 #72616 by 1942keremeos
Replied by 1942keremeos on topic Differential thrust
I have a few planes with diff thrust but I use a spectrum dx6 with them,simple only 2 mixes. One esc in throttle second in aux channel. Even to get duel rates with deviation is a long process. Kind of gave up let me know if you come up with a way. Thank you.
29 Jan 2019 20:43 #72617 by hexfet
Replied by hexfet on topic Differential thrust
See this thread . Need one channel for each motor. One way to do it is complex mix with two pages, first page has THR as source, second page is Add mix with rudder source scaled appropriately. Second channel is the same but with rudder inverted.
30 Jan 2019 18:26 #72627 by jejeg
Replied by jejeg on topic Differential thrust
My Model ini
Twin edf A10 warthog
File Attachment:
File Name: model26.ini
File Size:8 KB
02 Feb 2019 04:39 - 02 Feb 2019 04:41 #72667 by spacecase
Cool hey so now is when we can take the file from jejeg model26.ini and dump it into ones transmitter usb drive fold "models".
Then load new model on transmitter and pull that model up, it will be there?
This is fantastic we can see how you did it thanks, how cool that saves so much time.
Last edit: 02 Feb 2019 04:41 by spacecase.
02 Feb 2019 18:31 - 02 Feb 2019 18:32 #72672 by jejeg
Motor 1 : channel 3 (with devo receiver)
Motor 2 : channel 7
Do not connect on channel 4
Fmod0 : no mixing
Fmod1 : mixing on
Good flight
Jérôme
Last edit: 02 Feb 2019 18:32 by jejeg.
Time to create page: 0.293 seconds
