Emulator for testing telemetry
- MikeNH
08 Jan 2019 15:29 - 08 Jan 2019 15:32 #72236
by MikeNH
Emulator for testing telemetry was created by MikeNH
Last edit: 08 Jan 2019 15:32 by MikeNH. Reason: Corrected the jpg
08 Jan 2019 16:15 #72237
Replied by hexfet on topic Emulator for testing telemetry
Yes, the values are hard-coded and intended just for testing. They can be changed in the source code.
What are you trying to accomplish? (What do you mean by "configure accurate telemetry"?)
- MikeNH
08 Jan 2019 20:48 #72241
by MikeNH
Replied by MikeNH on topic Emulator for testing telemetry
I seem to be able to stumble onto fairly accurate RSSI but the Volt1 reading provides what appears to be the voltage of one cell. I don't want to take your time until I've had the opportunity to do research. In the telemetry configuration screen (Devo7e) there are voltage values that can be changed using the R+ and R- tx buttons. It appears that once the voltage has been selected, Hitting the ENT now brings up the opportunity to select the number of cells with that voltage.
In any case, I first need to know how to configure the flight controller & receiver.
I appreciate your time and the response.
Mike
Mike
08 Jan 2019 21:31 #72242
Yes the user manual in the left column will help. Check the FrskyX telemetry section and the Telemetry test page.
Time to create page: 0.106 seconds
- Emulator for testing telemetry
