Flysky FS-NV14 2.4G
- Betty1
21 Nov 2019 12:07 #75462
by Betty1
Flysky FS-NV14 2.4G was created by Betty1
What happens if 4IN1 is attached to Flysky FS-NV14 2.4G?
- propnut
21 Nov 2019 19:48 #75464
by propnut
Replied by propnut on topic Flysky FS-NV14 2.4G
Shouldn't you ask Flysky that question ?
- Fernandez
21 Nov 2019 21:06 #75465
by Fernandez
Replied by Fernandez on topic Flysky FS-NV14 2.4G
That should work fine with deviation Tx, it is AFHDSA 2A, toghether with ibus should perform nice. I have one but not yet flown.
I did not like the Flit Series aftermarket receivers I had much less range than with original Flysky, but they were too big.
- propnut
22 Nov 2019 18:18 - 22 Nov 2019 18:20 #75466
by propnut
The Flysky FS-NV14 is a TRANSMITTER !!! not a receiver so how exactly would it work with DeviationX. It is OpenTX based. The Devo 4in1 module is not the same as the 4in1's used in OpenTX radios as they have the firmware built into them. DeviationTX manages the protocols directly and just outputs to the relevant chips.
Last edit: 22 Nov 2019 18:20 by propnut.
- Fernandez
22 Nov 2019 22:16 #75468
by Fernandez
Ah sorry you are right, I thought it was about the FlySky FS-X14S which is there new micro receiver.Which should work with deviation.
The Nirvana runs open TX, noideaif it can control 4in1 multimodule, ask the open tx forum.
- Betty1
24 Nov 2019 12:25 #75470
by Betty1
Replied by Betty1 on topic Flysky FS-NV14 2.4G
The question was bad. My Jumper T8SG can no longer be connected via USB and will not be recognized by the PC, so I gave up and purchased the Flisky FS-NV14 but the JP4in1 has not yet arrived! The original question is, if JP4in1 is installed on NV-14, can it be used like Jumper T8GS? I don't know anything difficult, so I want to borrow your wisdom. Thank you.
- propnut
25 Nov 2019 20:41 #75482
by propnut
That radio runs OpenTX so yes, once you plug in the module it should work just fine.
Time to create page: 0.045 seconds
- Flysky FS-NV14 2.4G
