Devo 10 Screen issues
- Jingang123
04 Feb 2020 22:03 #75880
by Jingang123
Devo 10 Screen issues was created by Jingang123
Hi all, I have a devo10 which if flashed with deviation v5.0 but am having some problems with the transmitter. After using it for less than 2 minutes the screen becomes blocky and unreadable.
I was wondering if anyone else on here has had the same issue with the devo10 and if so how do I fix it? I have tried replacing the battery but still getting the same issue.
Thank you in advance!
- Mack775
05 Feb 2020 01:15 #75882
by Mack775
Replied by Mack775 on topic Devo 10 Screen issues
Is this your first time to flash a devo?
05 Feb 2020 03:55 #75883
Replied by vlad_vy on topic Devo 10 Screen issues
Most likely it's LCD problem. Try to reseat LCD cable, 16 pin connector, probably you also need reseat flat cable on the LCD board, under LCD screen.
- Jingang123
05 Feb 2020 10:52 #75884
by Jingang123
Replied by Jingang123 on topic Devo 10 Screen issues
Hi mack775, yes this is. I flashed the devo10 using the mac deviation uploader.jar.
- Jingang123
05 Feb 2020 10:56 #75885
by Jingang123
@vlad_vy Thank you for your reply. Could you please elaborate on what you mean by reseating the LCD cable? I have tried removing the ribbon from the main board but still having the same issue. Do I need to remove each of the 16 wires from the ribbon connected to the LCD panel?
05 Feb 2020 11:04 - 05 Feb 2020 11:16 #75886
Simply disconnect and reconnect this cable. There is another flat cable from LCD panel to LCD board. I don't know flat cable has connector or it soldered to the LCD board.
First try to rewrite USB drive filesystem from firmware archive. Just in case if filesystem is damaged. Use Safely Remove Hardware after write.
P.S. You can test LCD with USB mode. Press ENT button and Power On transmitter, if USB symbol on the screen is not distorted, the LCD screen is OK and you need rewrite USB drive filesystem.
Last edit: 05 Feb 2020 11:16 by vlad_vy.
- Mack775
05 Feb 2020 15:48 #75890
by Mack775
www.deviationtx.com/forum/builds/6407-de...-protocols?start=480
I have flashed about 10 devo 10s with this and no problems. And vlad_vy is nice to help users!!
- Mack775
05 Feb 2020 16:01 #75891
by Mack775
deviation uploader.jar. I have used this in linux have not got an apple, wife has an ipad but I am not brave enough to use it.
But I still use Notepad++ under wine for mods. When you get it to working more fun than anything.
Time to create page: 0.164 seconds
- Devo 10 Screen issues
