Would this Tx be compatible with my jumper t8sg v2
- osmeldu@gmail.com
09 Mar 2022 20:50 #77895
by osmeldu@gmail.com
Would this Tx be compatible with my jumper t8sg v2 was created by osmeldu@gmail.com
Hello.
I've been googling like crazy but I can't find a solid answer.
I want to use my Jumper T8SG V2 with this drone which has a FrSky R-XSR Tx:
GEPRC CineLog 25
It seems like it should work, but I want to be sure before buying it.
GEPRC CineLog 25
10 Mar 2022 00:01 #77896
Replied by hexfet on topic Would this Tx be compatible with my jumper t8sg v2
The R-XSR can work but the firmware version on it matters. The page doesn't have that information but there's one comment from someone who needed to re-flash the R-XSR.
Deviation supports the ACCST firmware, both versions 1 and 2. It does not support the ACCESS firmware. If you're comfortable re-flashing the XSR you can make it work.
- osmeldu@gmail.com
10 Mar 2022 00:19 #77897
Replied by osmeldu@gmail.com on topic Would this Tx be compatible with my jumper t8sg v2
Hello. thanks for answering.
I would be ok re-flashing the XSR receiver, can I do it with my jumper T8SG V2 plus with the pins behind? Or do I need a more advance transmitter like the Radiomaster TX16S?
thanks
thanks
10 Mar 2022 02:20 #77898
Deviation doesn't support flashing the receivers. An opentx/edgetx transmitter can do it. There's also some flashing software out there but a little circuitry is needed. That's at the bottom of the attached doc.
Time to create page: 0.065 seconds
- Would this Tx be compatible with my jumper t8sg v2
