Problems building
01 Jul 2013 19:56 #11685 by IMback!
Problems building was created by IMback!
I just tryed building deviation for the devo 7e (current PhracturedBlue repo) using arm-none-eabi toolchain (gcc v4.7.3) from arch aur. It errors out:
+ Building 'devo7e.elf'
objs/devo7e/pages.o:(.rodata.pages+0x120): undefined reference to `PAGE_DatalogInit'
objs/devo7e/pages.o:(.rodata.pages+0x124): undefined reference to `PAGE_DatalogEvent'
collect2: error: ld returned 1 exit status
make: *** [devo7e.elf] Error 1
I assume this is due to the work currently going on the devo 6/8/12 gui? how can i get old sources (for deviaton 3.0)?
01 Jul 2013 20:33 - 01 Jul 2013 20:34 #11686 by sbstnp
Replied by sbstnp on topic Problems building
The toolchain from ArchLinux AUR doesn't work. You should use summon-arm-toolchain script. Tried and tested by yours truly. It can eventually complete the build but the code just locks out/reboots the transmitter.
There's a virtual machine running arch in the How To section with everything installed:
deviationtx.com/forum/how-to/1200-vm-ded...-compiling-deviation
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 01 Jul 2013 20:34 by sbstnp.
  • rbe2012
  • rbe2012's Avatar
01 Jul 2013 21:02 #11689 by rbe2012
Replied by rbe2012 on topic Problems building
IMback! wrote: ...It errors out:...
I got the same errors with my standard MinGW on Windows build environment (even with make distclean). Looks like a real bug.
02 Jul 2013 03:28 #11702 by sbstnp
Dataloggin isn't supposed to be available on the 7E, so any reference to those pages is a bug indeed.
Still, the heads up about the AUR toolchain still stands.
Devo 10 + 4in1
Spektrum Dx9
02 Jul 2013 03:43 #11703 by PhracturedBlue
Replied by PhracturedBlue on topic Problems building
I checked in a fix for the devo7e build. As mentioned. follow the REAdME instructions, or use one of the pre-built solutions on the forums. The arm toolchains are very touchy, and you woon't be able to get any help if you don't use one of the documented methods.
Time to create page: 0.381 seconds
