Devo 12s PPM
17 Nov 2013 23:47 #15661 by Lasercopter
Devo 12s PPM was created by Lasercopter
Im trying to get my EZUHF that i have connected to the trainer port that has PPM output, i only seem to get 8 channels to work, does the devo 12s output more that 8 channels via the trainer port?
18 Nov 2013 05:19 #15667 by FDR
Replied by FDR on topic Devo 12s PPM
It is all about timing.
AFAIK this is what possible with standard pulse widths in a standard frame size...
Have you tried to change the PPM properties, for example increase the frame size to see if there could be more channels fit in. You can try to decrease the notch pw a bit too...
18 Nov 2013 05:26 #15668 by Lasercopter
Replied by Lasercopter on topic Devo 12s PPM
Is it possible to change the ppm properties using the stock software? do you decrease accuracy by adding more bits in the same stock space?
18 Nov 2013 05:28 #15669 by FDR
Oh no, with the stock fw yo can't change the PPM properties.
We are talking about deviation on this site...
  • rbe2012
  • rbe2012's Avatar
18 Nov 2013 06:37 #15671 by rbe2012
Replied by rbe2012 on topic Devo 12s PPM
AFAIK supports PPM only 10 channels (due to timing restrictions).
Time to create page: 0.623 seconds
