Devo 7e DSMX wont bind with orangeRX R720x v2
- Radmor
14 Feb 2016 22:06 #43128
by Radmor
Devo 7e DSMX wont bind with orangeRX R720x v2 was created by Radmor
Hello everyone,
Its quite some time since I have deviation on my devo7e, already faced many problems, but this one I can't find the answer anywhere.
So DSM2 works fine, but DSMX wont bind with the new orangerx. Strangely enough, with the released 4.0.1 it works just fine, but any nightys I tried failed to bind (I found only the newer nightys).
Since the file size is different under the protocol folder, I did try to replace it with the old file, but ofc I get the protocol error as soon as I start. I can't go back to 4.0.1 because I need the newer features.
Do you think that changes in the protocol causing it to fail in this case? Can I use the old DSMX protocol somehow with a nightly?
Thanks in advance!
Btw, awesome work!
Thanks in advance!
Btw, awesome work!
- Thomas.Heiss
14 Feb 2016 22:59 #43129
by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 7e DSMX wont bind with orangeRX R720x v2
Just an idea: Have you tried switching the DSMx option (A1, B1 or what it is now) in the popup dialog?
- Radmor
14 Feb 2016 23:34 #43130
by Radmor
Replied by Radmor on topic Devo 7e DSMX wont bind with orangeRX R720x v2
No, and I am unable to find it in the latest nightly. Where should it be? DSMX and ENT button?
- Radmor
15 Feb 2016 00:13 #43131
by Radmor
ohh and iam using the devo-s module, maybe its relevant.
- Cereal_Killer
15 Feb 2016 07:05 #43139
by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7e DSMX wont bind with orangeRX R720x v2
I use the same rx's and NEVER had a single issue with my 7E or 10...
First question, did you enable telemetry before attempting to bind?
- Radmor
15 Feb 2016 07:20 - 15 Feb 2016 07:20 #43140
by Radmor
No, Ive never touched the telemetry before. Now I have tried to add an alert event to see if it makes a difference somehow, but unfortunately no.
Last edit: 15 Feb 2016 07:20 by Radmor.
15 Feb 2016 07:20 - 15 Feb 2016 07:30 #43141
Replied by vlad_vy on topic Devo 7e DSMX wont bind with orangeRX R720x v2
I think if OrangeRX R720x can output 12 channels for CPPM and S.Bus, it's really more that 7 channels receiver and has to be bind with number of channels >7, i.e. 8 channels or more.
By the way, at nightly builds for bind packet added only:
if(Model.protocol == PROTOCOL_DSMX) {
#ifdef MODULAR
packet[12] = 0xb2;
#else
packet[12] = num_channels < 8 && Model.proto_opts[PROTOOPTS_TELEMETRY] == TELEM_OFF ? 0xa2 : 0xb2;
I don't know why it needed and what is it.
#ifdef MODULAR
packet[12] = 0xb2;
#else
Last edit: 15 Feb 2016 07:30 by vlad_vy.
- Radmor
15 Feb 2016 07:25 - 15 Feb 2016 07:39 #43142
by Radmor
Yes! You nailed it, thank you so much!
Even tho I am using PWM at the moment, just tried to bind with 10 channels, and whoala!
Thanks again!
Maybe just the channel number on default was higher in 4.0.1 thats why it worked, or that piece of code caused it somehow, i dont know..
vlad_vy wrote: I think if OrangeRX R720x can output 12 channels for CPPM and S.Bus, it's really more that 7 channels receiver and has to be bind with number of channels >7, i.e. 8 channels or more.
Thanks again!
Last edit: 15 Feb 2016 07:39 by Radmor.
- IKKI
20 May 2016 11:38 #48854
by IKKI
Replied by IKKI on topic Devo 7e DSMX wont bind with orangeRX R720x v2
I have some problems with orange R620x and sbus with dsmx protocol. I use Devo 7e and 5.0 firmware
- kaligola
26 Nov 2016 11:02 #56295
by kaligola
Replied by kaligola on topic Devo 7e DSMX wont bind with orangeRX R720x v2
i binded once one of this, if not remember wrong have to play with number of channels, didnt get more than 8 anyway and endpoints of tx
- Cereal_Killer
28 Nov 2016 04:39 #56331
by Cereal_Killer
What flight control board? Did you need to run an extrrnal S.Bus inverter?
Time to create page: 1.419 seconds
- Devo 7e DSMX wont bind with orangeRX R720x v2
