3 in 1 and 4 in 1 module connections for devo 12s
- Alexander-A
18 Dec 2016 17:40 #56957
by Alexander-A
3 in 1 and 4 in 1 module connections for devo 12s was created by Alexander-A
Hello, is there anyone yet who has the connections for the 3 in 1 and or the 4 in1 module for the devo 12s.
Have not found it till know.
Alex
Alex
- Arnold
18 Dec 2016 22:25 - 18 Dec 2016 22:27 #56961
by Arnold
For the 4in1, see post #55157
If you are logged in, use this link:
www.deviationtx.com/forum/7-development/...dule?start=160#55157
.. and scroll down to the Devo12 pix
If you are NOT logged in, use this link:
www.deviationtx.com/forum/7-development/...dule?start=940#55157
Replied by Arnold on topic 3 in 1 and 4 in 1 module connections for devo 12s
Alexander-A wrote: Hello, is there anyone yet who has the connections for the 3 in 1 and or the 4 in1 module for the devo 12s...
Last edit: 18 Dec 2016 22:27 by Arnold.
- dat
19 Dec 2016 09:24 - 19 Dec 2016 10:21 #56973
by dat
Replied by dat on topic 3 in 1 and 4 in 1 module connections for devo 12s
3 in1 work fine in my 12S ,
install deviation main FW ver : deviation NB-devo12-v5.0.0-f9f36d5
and
Firmware DFU file from vlad_vy,
: Deviation v5.0.0 build with latest protocols
my hardware.ini
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
; enable-multimod = A13
and
my hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Last edit: 19 Dec 2016 10:21 by dat.
- jejeg
19 Dec 2016 20:09 #57011
by jejeg
Replied by jejeg on topic 3 in 1 and 4 in 1 module connections for devo 12s
Hello dat
Have you photos of your assembly .
Jérôme
Jérôme
- Alexander-A
20 Dec 2016 06:17 #57030
by Alexander-A
Replied by Alexander-A on topic 3 in 1 and 4 in 1 module connections for devo 12s
Hello, you say that the 3in1 module works fine in your 12s, but do you have then a layout for all the connections, so where in the 12s to solder all wires to ?
Hope you can help me,
Alex
Alex
- dat
20 Dec 2016 15:01 #57040
by dat
i didn't have photo post now, because i hadn't take any photo that time when i solder this board
as fast as i will do open my tx take some photo for you soon
- dat
20 Dec 2016 16:08 - 20 Dec 2016 16:10 #57042
by dat
Last edit: 20 Dec 2016 16:10 by dat.
- Wene001
20 Dec 2016 16:25 #57043
by Wene001
Replied by Wene001 on topic 3 in 1 and 4 in 1 module connections for devo 12s
I would recommend to use the 4in1 Module made especially for Devo.
It has his own voltageregulator powered from the stable 4,25V from the module bay.
The 3,3V used in the pictures is very weak.
If you use the onboard 3,3V you have fluctuating Voltage and the analog input reading is messed up.
if you want to go the 3in1 way i would drop down the stabilized 4,25V from the module bay for the 3in1 module.
(Diodes in series or a linear voltageregulator)
- Alexander-A
20 Dec 2016 18:51 #57055
by Alexander-A
Hello, thanks for the info, but its still hard to see where all the wires are going from the module to the transmitter. Maybe you can somehow make more claerly, maybe make a sketch ?.
I hope i'm not asking to much from you.
You also think its better to use the 4in1 module, do you have the connections for these as well ? (for the devo 12s i mean.
Hope you can helk me out.
Thanks,
Alex
Thanks,
Alex
- M8A4X
- M8A4X
21 Dec 2016 01:33 #57073
by M8A4X
Replied by M8A4X on topic 3 in 1 and 4 in 1 module connections for devo 12s
Hi Alex,
there recently was a thread regarding the Devo 12 and the 4in1 module installation.
You can find it here:
Devo 12 - 4in1 module installation
You can also find sketches of the wiring there.
Best regards
Max
Best regards
Max
- Wene001
21 Dec 2016 09:31 - 21 Dec 2016 09:32 #57086
by Wene001
I would recommend this module
www.banggood.com/CC2500-NRF24L01-A7105-C...07.html?rmmds=search
So you have to connect only 3 wires to TMS, TCK, and B3
as mentioned in the thread linked above
I have this configuration and i works like a charm
all Chips transmitting via the original devo 12s antenna
Last edit: 21 Dec 2016 09:32 by Wene001.
- dat
21 Dec 2016 11:06 - 21 Dec 2016 11:07 #57092
by dat
hi Alexander
i do not have 4 in 1 , i can't tell you which is better
but ,
3 in 1 need solder many point and that is more complicated than 4 in 1
4 in 1 only 3 wires need solder and one antenna that is awesom , isn't it ?
4 in 1 maybe better for you if you have not own a 3 in1
simple way is always better that's what i thought ,
but ,
Last edit: 21 Dec 2016 11:07 by dat.
- backman8571
14 Mar 2019 22:50 #73362
by backman8571
Replied by backman8571 on topic 4 in 1 module connections for devo 12s
So how do you wire it
Thats the one i have
Per
Per
- jejeg
Time to create page: 1.646 seconds
- 3 in 1 and 4 in 1 module connections for devo 12s
