Devo8 with vibration (updated for deviation 4.0.1)
26 Mar 2013 15:54 - 20 Jan 2014 13:34 #8113
Devo8 with vibration (updated for deviation 4.0.1) was created by rbe2012
EDIT: new version based on deviation 3.0.0 4.0.1
This build needs a hardware mod described here .To use it you have to set manually a parameter "has_vibration=1" in the tx.ini file (after having done the mod, for sure). (Edit: not longer necessary)
It does not work for the Devo12 because the used output pin is in use there.
In the tx config there is a new option to switch vibration on or off (sets parameter in tx.ini accordingly).
EDIT:
Build for Deviation 3: see next post.
2nd EDIT:
Build for Deviation 4.0.1 attached here (unzip and flash). You will find a button on the third tx config page where you can switch vibrating off or on and test it (by pressing the button).
EDIT:
2nd EDIT:
Last edit: 20 Jan 2014 13:34 by rbe2012.
08 Apr 2013 18:38 #8756
Replied by rbe2012 on topic Devo8 with vibration (updated for deviation 3.0)
Corrected an error in initializing (if vibration was set off when the tx was switched on, it could only changed when the tx was switched off and on).
Here is the new version:
- RandMental
09 Apr 2013 19:26 - 09 Apr 2013 19:27 #8804
by RandMental
Replied by RandMental on topic Devo8 with vibration (updated for deviation 3.0)
Hi RBE
Do you have the V3 with vibration source somewhere in a repo where I can get it and try to make a patch file that I can apply when we build PB's latest V3.x.x source files?
Last edit: 09 Apr 2013 19:27 by RandMental.
10 Apr 2013 06:33 #8818
Yes, you can take it from my repo here:
rbe-vibrating
. I have sent PB a pull request (#55).
- RandMental
10 Apr 2013 14:32 #8827
by RandMental
rbe2012 wrote: Yes, you can take it from my repo here: rbe-vibrating . I have sent PB a pull request (#55).
- crasy666
04 Jan 2014 22:06 #17951
by crasy666
Replied by crasy666 on topic Devo8 with vibration (updated for deviation 3.0)
Will the vibration work on V4. Or can somebody make a build with the vibration mod on V4?
I like the vibration feature on my Devout 8S especially in the winter time with a transmitter glove, where you don't hear the buzzer too good
Thx in advance
Btw, I am using a vibration motor from a cell phone, works great and is designed for 3V so just a transistor BC548 a 100 Ohms resistor and a diode...
Thx in advance
- -=Hubi-Dirk=-
05 Jan 2014 07:56 #17971
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo8 with vibration (updated for deviation 3.0)
Hi rbe2012,
would you be so kind and provide a version of the firmware 4.01 for the Devo 8s with the vibration feature?
Thanks in advance,
Dirk
Thanks in advance,
Dirk
- RandMental
05 Jan 2014 08:55 #17972
by RandMental
Hi RBE,
I would also appreciate the AUX4/AUX5 and Vibration patch files for the latest V4.01
RM
RM
- richardclli
06 Jan 2014 15:50 #18079
by richardclli
Replied by richardclli on topic Devo8 with vibration (updated for deviation 3.0)
I am about to work out the vibration mod as well. Any update on this?
06 Jan 2014 16:08 #18080
Yep, I have seen your requests. I have lost it out of sight due to other priorities for a while, but I still have mounted the vibrating motor in my Devo8.
Time to get it rumbling!
06 Jan 2014 18:59 #18089
Ok, I have updated the first post with the new build. Attached here you can find the patch file (patch -p 1 -i diff_Vibration_4.0.1.txt).
Some gui elements have changed since 3.0 so I had to make it completely new, but there are only a few changes.
06 Jan 2014 19:15 #18092
Do you thing it works now?
Have I provided a version for 3.0 or even 2.1.1? I don't remember.
I think I have lost what I have done before (since I did not find a patch file...). But I will surely be able to redo this.
The last thing I herad from this AUX4/AUX5-mod was "let's have some testing" ...RandMental wrote: Hi RBE,
RM
- -=Hubi-Dirk=-
06 Jan 2014 19:23 #18093
by -=Hubi-Dirk=-
Hi rbe,
thank you very much for your work. I can no longer imagine the time with my the Devo 8s without vibration.
For those who still have not heard from this great Mod, follow this link:
deviationtx.com/forum/how-to/1501-Devo-8...vibration-motor#8710
06 Jan 2014 19:38 #18094
RandMental,
I sent you a PM with link to test-version.
- crasy666
07 Jan 2014 20:20 #18158
by crasy666
Hi rbe,
Thank you so much, great job!
I have updated today my Devo 8S all including the vibration alarm is working great.
Regards
Regards
23 Jan 2014 10:05 #18982
Since adding a vibrating motor to a Devo8 is supported by the main deviation code in the actual nightlies no further patches are necessary.
AUX4/5 is not yet supported.
Time to create page: 1.193 seconds
Builds
- Devo8 with vibration (updated for deviation 4.0.1)
