HiSky experimental build
- victzh
25 Mar 2015 05:03 - 26 Mar 2015 05:01 #30226
by victzh
HiSky experimental build was created by victzh
This is HiSky experimental build
Last edit: 26 Mar 2015 05:01 by victzh.
- mtx63
26 Mar 2015 08:18 #30285
by mtx63
Replied by mtx63 on topic HiSky experimental build
What improvements are there.
I have devo 7e.
Next nightly builds --> hisky2.
Dieter
I have devo 7e.
Dieter
- victzh
26 Mar 2015 15:51 #30299
by victzh
Replied by victzh on topic HiSky experimental build
It's a test implementation of HiSky protocol for new HCP80 v2. Channel 7 should control gyro mode, if it's <=0 it's 6-axis mode, if it's >0 - 3-axis mode. It may or may not work, mind you. Set the number of channels to 7 for the model.
- Babay
27 Mar 2015 11:28 #30325
by Babay
Replied by Babay on topic HiSky experimental build
Today I have builded the latest Deviation Team firmware with 7-ch HiSky patch. Tested on HCP80V2 - 3D/6G switch work correctly.
- robocog
23 Jul 2015 13:52 #35852
by robocog
Replied by robocog on topic HiSky experimental build
Should this work on a 7e TX?
I am running deviation-devo7e-v4.0.1-e1a3b14 nightly
I tried to put the dfu on - but it refused to boot with it
I have rolled back to the nightly as the TX is used for all the choppers and quads, but would dearly like to switch the HCP80 that just landed on my doorstep into 3D mode, its boring as is gets in 6g!
Regards
Rob
Regards
Rob
- robocog
23 Jul 2015 16:05 - 23 Jul 2015 16:06 #35865
by robocog
Looks like I needed to get the latest Nightly build to gain the 7th channel for Hisky on my Devo 7E- I can confirm that updating to it worked for me
Not a clue why the file linked in here did not work for me
Regards
Rob
Regards
Rob
Last edit: 23 Jul 2015 16:06 by robocog.
Time to create page: 0.297 seconds
Builds
- HiSky experimental build
