Experimental Build on Protocols size optimization
- TheSFReader
06 May 2016 09:55 - 06 May 2016 09:56 #47865
by TheSFReader
Experimental Build on Protocols size optimization was created by TheSFReader
I've worked on protocol optimizations for DSM2/X (gained a few hundreds bytes) and a small one for Devo. I don't have receivers to test against them, and would like to make sure there is no regression. How should I post experimental builds ? Should I also post a "non-modular" build with it to check before requesting a pull ?
(My repo github.com/TheSFReader/deviation )
Last edit: 06 May 2016 09:56 by TheSFReader.
07 May 2016 16:07 #47967
Replied by PhracturedBlue on topic Experimental Build on Protocols size optimization
07 May 2016 16:28 #47971
By the way, the code looks good, but I might prefer to use a makefile mod to generate dsmx_cyrf6936.bin rather than a separate .c file. I haven't given it too much thought yet, so I dunno which way I'd want to go yet.
- TheSFReader
07 May 2016 19:24 #47984
by TheSFReader
Replied by TheSFReader on topic Experimental Build on Protocols size optimization
Yeah, quite "hacky" that way, but a makefile mod is above my limited makefile knowledge...
As for the upload build scripts, do I really need to install a mercurial repo (and probably utilities), while the code is on GH ?
07 May 2016 20:12 #47987
no. I updated the instructions. it uses git now
- TheSFReader
08 May 2016 21:13 #48073
by TheSFReader
Uploded the build on
www.deviationtx.com/downloads-new/catego...mizations-for-devo7e
If people could test the Devo, DSM2 and DSMX compatibility (especially for more than 8 channelson DMSX) for no regression, it would be great.
Time to create page: 0.390 seconds
Builds
- Experimental Build on Protocols size optimization
