Channel Monitor does not work in 7E
29 May 2016 16:03 #49507 by 92zb
I just installed latest nightly deviation-devo7e-v5.0.0-db9ca98, and the channel monitor does not work only Ruder partially works, it only work from 0 to -100. When TX is switched on it shows Channel 3 is 0% safe value = -100, if you move the relvent stick, it does not go. Changed the channel in box 1 to channel 1, when you switch on the TX still channel 3. There is more problem, the model ini which I setup shows correctly in Note Pad, but on mixer page in one the channels the switch which was assigned to it has changed, this software does not allow to switch back to the original switch.
The problem of EXIT still exit .
29 May 2016 16:30 #49508 by HappyHarry
Replied by HappyHarry on topic Channel Monitor does not work in 7E
i just checked this and i can't replicate the channel monitor issue, can you load a fresh blank model, calibrate the sticks and try again?
i'm in the middle of finding out where the screens are the ext doesn't work, once i find them all i'll post a bug on the tracker
29 May 2016 17:23 #49509 by Cereal_Killer
Replied by Cereal_Killer on topic Channel Monitor does not work in 7E
HH, I've got a bug report already filed for the EXT button not working. Feel free to add your info there.
29 May 2016 17:23 #49510 by 92zb
Replied by 92zb on topic Channel Monitor does not work in 7E
I reinstalled the nightly and every thing is ok, except EXICT inTX config after caliberating you have to switch off the TX. I have already reported this bug.
29 May 2016 18:54 #49516 by HappyHarry
nice one guys, I'll add my info to the existing bugs
29 May 2016 21:34 #49525 by 92zb
More problem in this latest nightly. I have Cheerson X10, it was working fne, but in this nightly, non of the sticks work, throttle on its own about10%, it only hover about few inches from the ground. I also have Eachin 8 and LS114, it does not bind at all. I reverted back to 4995383, they all work ok.
29 May 2016 23:49 - 29 May 2016 23:50 #49527 by HappyHarry
I think something weird is happening when loading model files, I'll look into it more tomorrow and see if I can track down what's actually changing and what steps to reproduce it
Last edit: 29 May 2016 23:50 by HappyHarry.
30 May 2016 17:31 #49577 by 92zb
There is something weird in this latest nightly. I tried it on my Syma X5c, its control are upside down. Throttle and Elevator ok but rudder stick behaving as aleron and aleron as rudder.
04 Jun 2016 19:36 #49925 by Cereal_Killer
Rudder and AIL swapped is mode 4, that's strange, is the swap in the inputs or the output?
Time to create page: 1.174 seconds
