Clock not working : deviation-devo12-v5.0.0-b28961
- pulpfiction15
08 Aug 2016 12:40 - 08 Aug 2016 12:40 #52578
by pulpfiction15
Clock not working : deviation-devo12-v5.0.0-b28961 was created by pulpfiction15
Yesterday I installed the latest Nightly build: deviation-devo12-v5.0.0-b28961.
I have a minor bug.
I can set date and time, and it is working nicely as long as the power is on.
When I power down and up again, time is reset.
Hoping to have informed you.
Regards,
Rudi
I have a minor bug.
Regards,
Rudi
Last edit: 08 Aug 2016 12:40 by pulpfiction15.
08 Aug 2016 12:51 #52580
Replied by FDR on topic Clock not working : deviation-devo12-v5.0.0-b28961
Most probably the clock battery is flat.
Does it work if you go back to the last used version?
- pulpfiction15
08 Aug 2016 13:02 #52581
by pulpfiction15
Replied by pulpfiction15 on topic Clock not working : deviation-devo12-v5.0.0-b28961
v5.0.0 is working.
08 Aug 2016 14:51 #52586
Have you reverted and checked, or it was just working before the upgrade?
The battery could go flat since that...
- pulpfiction15
08 Aug 2016 18:34 #52590
by pulpfiction15
FDR, You are right, I have 'downgraded' back to V5.0.0, and have the same.
So Clock battery has to be changed.
Thanks.
Thanks.
Time to create page: 0.806 seconds
Builds
- Clock not working : deviation-devo12-v5.0.0-b28961
