Ultimate Devo F12E (devof12e-XMS) builds
- Moeder
23 Mar 2017 13:12 #60607
by Moeder
Replied by Moeder on topic Ultimate Devo F12E (devof12e-4MB) builds
Eventually it should work on both, but let's stick with 4mb users for now
- DIGGIDY
23 Mar 2017 13:30 #60609
by DIGGIDY
Replied by DIGGIDY on topic Ultimate Devo F12E (devof12e-4MB) builds
Ok I have the 4BM chip installed, so when I installed the dfu, then switched off, unplugged and switched the tx back on it went straight into usb mode. If i plug in the usb cord its displays the windows file manger and shows a devo.fs file, not the expected file system. If I revent back to the old dfu it work as expected with all my file system intact.
So I guess thats not working..?
- rdowzall
23 Mar 2017 13:37 #60610
by rdowzall
Replied by rdowzall on topic Ultimate Devo F12E (devof12e-4MB) builds
Just tried on my 4mb f12e.....same results as Diggidy. In USB the old devo.fs file only showed up. Tried navigating around model set-up / Transmitter set-up and lots off issues. Hope that helps
- Moeder
23 Mar 2017 13:38 #60611
by Moeder
23 Mar 2017 17:17 - 23 Mar 2017 17:20 #60629
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
Last edit: 23 Mar 2017 17:20 by vlad_vy.
24 Mar 2017 06:37 - 24 Mar 2017 06:39 #60665
I think about: How newcomer will know what tools to use for flashing that universal version? By the method of scientific poking?
Last edit: 24 Mar 2017 06:39 by vlad_vy.
- Moeder
24 Mar 2017 07:04 #60666
by Moeder
I thought we could make a universal dfu, but make two zips in nightly and release containing different file systems. For smaller changes (like new protocol) , one would only have to update the universal dfu. Or am I thinking wrong?
25 Mar 2017 08:42 - 27 Mar 2017 16:40 #60719
Last edit: 27 Mar 2017 16:40 by vlad_vy.
- Moeder
26 Mar 2017 08:37 #60756
by Moeder
I thought a lot about it, but came to the conclusion that it really does not make sense. Autodetection would mean needing to include devofs and petitfsin a single build, and this will definitely not fit f7. And since to avoid confusion we would still need two zips anyways, I do not think it's worth doing this huge code change. I think a flash detection enabled f12e-4mb and the regular f12e build are the way to go.
Moeder wrote: I thought we could make a universal dfu, but make two zips in nightly and release containing different file systems. For smaller changes (like new protocol) , one would only have to update the universal dfu. Or am I thinking wrong?
26 Mar 2017 10:03 #60763
Replied by FDR on topic Ultimate Devo F12E (devof12e-4MB) builds
All right then...
- DIGGIDY
27 Mar 2017 10:59 #60795
by DIGGIDY
I'm having an issue with the screen switching off whilst in flight on the F12E, it seems to be related to the dimming functionality in the transmitter menu, so I don't think it is specific to just the 4MB build.
I can't seem to find an option to disable this while in flight, or maybe I'm missing something.
I like the idea of the screen switching off if I'm not in flight and I put my tx down for say 5 mins or so to save battery life, but doing it in flight in FPV at speed is a no, no. I don't have FPV glasses yet, so I don't know if it does the same in this mode, I'd imagine this would not be a an issue.
27 Mar 2017 14:58 - 27 Mar 2017 15:00 #60802
I also don't like dimmer in time FPV flight.
I can to do disable dimmer if video enabled and vice versa. Will it is enough for you?
For me that's enough.
Last edit: 27 Mar 2017 15:00 by vlad_vy.
- DIGGIDY
27 Mar 2017 15:19 #60803
by DIGGIDY
yes, I think that should be enough. However I have setup my camera feed to enable when it see more than -100% throttle, will that still work and disable the dimmer function at the same time?
27 Mar 2017 15:33 - 27 Mar 2017 15:47 #60805
If you enable video by any Tx switch (or channel) it will disable dimmer. If you disable video by any Tx switch (or channel) it will enable dimmer. No matter the actual transmission of video.
Last edit: 27 Mar 2017 15:47 by vlad_vy.
27 Mar 2017 16:33 - 30 Mar 2017 16:08 #60809
* Fix GUI_DrawXYGraph()
* Fix XY-graph scaling for 128x64x1 GUI
* Disable screen dimmer function if video enabled and vice versa
DevoF12E and DevoF12E-4MB, with fixes, based on Nightly Builds:
File deleted, see below...
Last edit: 30 Mar 2017 16:08 by vlad_vy.
- DIGGIDY
27 Mar 2017 16:58 #60811
by DIGGIDY
That works a treat
Thanks for fixing that so quickly vlad.
- Artus
29 Mar 2017 16:46 #60909
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Ultimate Devo F12E (devof12e-4MB) builds
Now - i am glad to have also an Ultimate-Version of the F12E. I let a "profi" the exchanging the chip and he made a proper job - and the installation of vlad's files was no problem.
THANK YOU Vlad_vy !!!!
30 Mar 2017 16:09 - 06 Apr 2017 10:34 #60945
WARNING!!!
* Reverse AUX4 and AUX6 inputs to be uniform with Devo12
DevoF12E and DevoF12E-4MB, based on Nightly Builds:
Files deleted, see below...
Last edit: 06 Apr 2017 10:34 by vlad_vy.
- DIGGIDY
31 Mar 2017 08:39 #60971
by DIGGIDY
This is for the gimbal controls on the side of the tx yes? Why do we need to reverse them?
31 Mar 2017 08:50 - 31 Mar 2017 08:52 #60972
For all stock transmitters I have, sliders have next behaviour: if any slider moved up to the top of transmitter, value will change to the positive side. But AUX4 and AUX6 change value to the negative side. We had the same problem at the begining Deviation for Devo12.
Last edit: 31 Mar 2017 08:52 by vlad_vy.
Time to create page: 0.305 seconds
Builds
- Ultimate Devo F12E (devof12e-XMS) builds
