Vibration not working on Devo 12E
27 Oct 2017 00:54 - 27 Oct 2017 19:54 #65290 by andrej
Vibration not working on Devo 12E was created by andrej
My Devo 12E beeps, but doesn’t vibrate. Vibration is switched on in the menus; settings are exactly the same as on my Devo 10 where vibration works. Both have the latest 5.0.0 + new protocols version installed.
Is this a known issue? Or should I look for a hardware failure? (Can one order whatever the vibrating part is and swap it?) I stumbled upon this issue with Devo 7 , but it’s quite likely unrelated.
Last edit: 27 Oct 2017 19:54 by andrej.
02 Feb 2018 19:47 #67367 by andrej
Replied by andrej on topic Vibration not working on Devo 12E
Poking this thread, hoping that someone might already know how to tackle this.
Which component generates the vibrations? Where is it located on the PCBs? Is it just a standard part that I could buy somewhere and replace? I guess that would be the best thing to try at this point.
02 Feb 2018 22:27 #67371 by hexfet
Replied by hexfet on topic Vibration not working on Devo 12E
The attached pic has the vibration motor circled. It's probably a standard part but have never tried to look it up.
Time to create page: 0.378 seconds
