JUMPER T8SG V2 PLUS with R9M 2019
- Pedro28july
14 Dec 2019 07:15 #75580
by Pedro28july
JUMPER T8SG V2 PLUS with R9M 2019 was created by Pedro28july
Hello everyone, is there anyone to be able to successfully use R9M2019 with T8SG V2 Plus? I really appreciate if you explain step by step how you made it work. Thank you
- Fernandez
14 Dec 2019 09:47 #75583
by Fernandez
Replied by Fernandez on topic JUMPER T8SG V2 PLUS with R9M 2019
Can you confirm you flashed your module with latest Flex Firmware:
2019-02-13 190117 Fix the incorrect telemetry issue
I use this on my R9M ( non 2019 version)
Make sure to use Nightly build with PXX, made by HEXFET.
It should work. If have time will flash my radio with latest nightly to see if all still works. (As I still use version from quite some time ago)
(with regards to nightlies I lost a bit track and find very confusing, the nr ing of builds and what is actually inside)
- Fernandez
15 Dec 2019 14:56 - 15 Dec 2019 14:58 #75590
by Fernandez
Ok I did just flash the latest nightly build to my T8SG V2 Plus and I can confirm for me the R9M (not 2019) flashed with FLEX firmware works fine, as it did before.
So I assume yours should work too. (So there is nothing broken in the current nightlies)
(The new ACCES OTA R9 2019 firmware etc, possibly may use PXX2 protocol not yet in Deviation, so this likely not work)
Last edit: 15 Dec 2019 14:58 by Fernandez.
Time to create page: 0.112 seconds
Builds
- JUMPER T8SG V2 PLUS with R9M 2019
