Devo 8
- stevecox
- Keep swinging
- WheresWaldo
- WheresWaldo
21 Oct 2013 17:45 - 21 Oct 2013 17:56 #14849
by WheresWaldo
You have to use the 3.1 nightly from rbe, the layout file will go into the /layout directory. You can now use the exact same file for Devo 8 (it will show 8 channels and model icon) or Devo 7/10 (it will show 6 channels and no model icon).
BTW, there are no R E A icons with up arrows in Devo 7/10 so I used the down arrows and the inverse when toggled. Tell me what you think.
You could also add the [gui-480x272] section to the ini file and it would customize the same gui for the Devo12. It would sure be nice if we could just have one set of ini files to cover the whole range of Devo TXs.
Replied by WheresWaldo on topic Devo 8
I fixed it, look here it does work! vlad you have to think outside the box sometimes.vlad_vy wrote: These layouts are for Devo8, for Devo10/7 they do nothing.
Last edit: 21 Oct 2013 17:56 by WheresWaldo. Reason: More clarifying text.
Time to create page: 0.316 seconds
