How to set up FBL helis on Custom Firmware
- Hexperience
01 Dec 2012 21:28 #3510
by Hexperience
How to set up FBL helis on Custom Firmware was created by Hexperience
Here's my blog post on setting up a FBL heli on deViation and er9x
Might help someone... cheers
www.rcgroups.com/forums/showthread.php?t=1780870
- CamDLux
02 Dec 2012 22:36 #3522
by CamDLux
Replied by CamDLux on topic How to set up FBL helis on Custom Firmware
Thanks for doing this write up. I am trying to get my head around the configuration so, I can sell my DX8 before everyone catches the Deviation fever!
- Rain4LA
05 Dec 2012 16:29 #3665
by Rain4LA
Replied by Rain4LA on topic How to set up FBL helis on Custom Firmware
I really appreciate the time and effort that you put into this. It's really helpful. I just a one question (for now) When programming a helicopter that is designed to be run by a DSM2, do you then have to program the Devo channels to match what that Rx is programmed to? In other words, is the correct configuration on a MSRX, for example T-E-A-R. and not E-A-T-R?
- Hexperience
05 Dec 2012 16:40 #3667
by Hexperience
Replied by Hexperience on topic How to set up FBL helis on Custom Firmware
Correct. The cool thing is that deViation does it for you. When you select DSM2 as the protocol it automagicly sets the channel order for spektrum. TAER.
- Rain4LA
05 Dec 2012 16:56 #3668
by Rain4LA
Thanks! You da man...
(Even though I can't get the left stick to work using the Devo with Deviation - only the right stick. But I can get it to work using a Spektrum DX5e!)
- Hexperience
05 Dec 2012 17:14 #3670
by Hexperience
I just replied to the post in the config section... post your ini file and I can have a look if it's still not working. I don't have an MSR but we can figure it out...
Cheers
Cheers
- Rain4LA
05 Dec 2012 17:27 #3671
by Rain4LA
Thank you. Here's my .ini file. It's very simple - but I thought it should work.
- Hexperience
05 Dec 2012 17:33 - 05 Dec 2012 17:33 #3672
by Hexperience
Set the channels to 7. 4 channel has been problematic. And rebind...
Last edit: 05 Dec 2012 17:33 by Hexperience.
- Rain4LA
05 Dec 2012 17:39 #3673
by Rain4LA
That worked! You are the man! I love it when it's a simple fix like that!
THANK YOU!
THANK YOU!
- Hexperience
05 Dec 2012 18:02 #3674
by Hexperience
I am in fact, not the man. PB is the man. I am a 45 year old kid playing with my toys...
- Rain4LA
06 Dec 2012 04:32 - 06 Dec 2012 17:20 #3692
by Rain4LA
I erased a big post that had nothing to do with this stuff. It was the servos...
Last edit: 06 Dec 2012 17:20 by Rain4LA.
- Hexperience
06 Dec 2012 21:02 - 06 Dec 2012 21:03 #3718
by Hexperience
I read it on my phone and was going to comment, I think it was something about a model of heli I don't have... that and something about stalking...
Glad you got it worked out.
Last edit: 06 Dec 2012 21:03 by Hexperience.
Time to create page: 0.625 seconds
